Question about Indesit WA 125 Front Load Washer
How do I open the drum in an Indesit washing machine
There's something stuck in there rattling around and I need to remove it - any ideas?
    President:
  • 1,462 Answers
Remove back cover. remove heater held in by 1 10mm nut, prize heater out and you can see into the gap between tub and drum and fish object out
Posted on Sep 06, 2008
I have an LG troll washer that is making a loot of noise from the drum. And is bouncing around. It sounds like something is rattling around exterior of drum.
Sounds like a coin, nail screw or bra wire stuck in the drum / tub cavity. It will be difficult to remove if so - try removing the water heater and looking with a torch into the hole - if something is stuck on the front lip edge of the wash drum, you may need to strip the wash tub to pieces or replace - (good luck with that!) and it will have caused damage of some sort. ALWAYS check trouser pockets before washing!!
Avoid lying the machine on its side as water from the soap drawer or sump will probably run onto the expensive electronics cards.
Feb 03, 2018 | LG Washing Machines
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
Indesit WIL143UK knocking noise
Most likely the suspension gone a bit loose. Try with lesser load
Nov 10, 2013 | Indesit W 123 Front Load Washer
My Indesit WIL163 is stuck washing - won't go on
I suspect that the logic board has developed a fault and probably needs replacing. 'Phone your Indesit Service Centre and get an engineer out. I believe a replacement board costs about £100 fitted, but a 12-month service plan paid monthly may be a bit cheaper, and will cover further breakdowns. Unfortunately, these boards are not the most robust or reliable examples of technology.
Turn off the power to the machine; preferably unplug it.
If you can open the door(?), bale out the drum by hand. I don't think there's a pump/filter access panel on this machine, so it's not easy to get the water out. You could try
disconnecting the discharge hose from the pipework, then lower the open end over a washing-up bowl so that the water drains from the drum by gravity. It depends how close to the floor you can get the open end. When enough water has drained, it should be possible to open the door to remove the laundry. Sorry, this may take a while.
Hope this has helped.
Jan 11, 2018 | Washing Machines
Remove bearing from indesit drum how to split drum
all of the newer indesit washing machines have whats called a welded drum meaning they cannot be split open.the thing about this is to change the bearings you have to buy a full drum. best option is to go through the indesit company themselves. aprox cost £100 if under 5 years and £140 if over 5years. hope this helps
Jun 19, 2011 | Washing Machines
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Remove the drum on a top loaded washing machine
odds on something being between the tub and basket is very small.  noise probably coming from brake/clutch or transmission just to name a few possibilities...
Jul 24, 2010 | Whirlpool Washing Machines
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Jul 28, 2009 | Washing Machines
Indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
May 20, 2008 | Indesit W 123 Front Load Washer
Indesit WA 125 Front Load Washer Logo
254 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
