Question about Whirlpool Washing Machines
F1 code when start Whirlpool Cabrio Washer and sometimes during cycle - my machine is about a year old. Should I call a repairman or live with it?
    Genius:
  • 1,028 Answers
Control problem probably main control module..if in warranty (less than 1 year)CALL REPAIR NOW!!!!!!!!!!!!!! if not as long as it doesn't get too annoying or quits completely use it..control 200-275
Posted on Sep 06, 2008
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
    Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
    Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    I HAVE A WHIRLPOOL TOP LOAD CABRIO WASHER MOD. #WTW6400SW1 I AM GETTING A F1 CODE SOME TIME AT WASH CYCLE SOMETIME ON RINSE CYCLE WHAT ISTHE PROPLEM
    Hello
    Error code F1 is caused when the control on your washer is either bad or about to go bad. This is a common issue with Whirlpool Cabrio washers and they are aware of this. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge you for the part. Please get back to me if you have any other questions.
    Kevin
    Nov 14, 2010 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
    When we try to wash a load of laundry after a couple minutes we get the code F1 show up and the wash cycle turns off. What is F1 and how can we fix it so the Whirlpool Cabrio washer will work again?
    We have had the same problem for three years. We are only using this washer about 4 months a year. We has two service calls..no help. We had to baby sit the washer just like all the other posts, pressing pause about five or six times or more.
    Well, I read the posts & that Whirlpool had fixed this problem, paying for parts & labor..we called..they sent a repairman. It took him 20 minutes, he asked if this was the code, said he carried at least three of these parts & now..the washer has been running fine. three loads so far.
    So, call them, tell them the problem & it will be fixed at no expense to you..or should be.
    Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Our Cabrio Washer shows a F1 code during operation? Can yo help us with this problem? John & Kathy
    Hi
    Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. To remove and replace the control you’ll have to unplug the washer and then remove
    three screws from the rear of the console assembly. Pull console towards front of washer to hinge open and/or remove console. Then remove the one screw holding the machine/motor control assembly to the console tray and two plastic legs on the rear of the machine/motor control assembly that fit into the console tray. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jun 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Error f1 flashes after just a few seconds of turning on the wash cycle. if i turn off power and try to start again it will somtimes start if not i turn off and try again sometimes it takes 3 or 4 times to...
    The Whirlpool Cabrio and Kenmore Oasis (same machine) are infamous for this problem. Depending on the serial number you may be entitled to a new control board installed for free under a recall program. Call Whirlpool for eligibility. I had just had mine replaced last week for free and it runs fine now.
    Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washer stops with an F1 Code during rinse cycles.
    Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
    Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Error message on WTW6200sw
    Called Whirlpool to report the F1 problem on my over 2 year old, out of warranty, Cabrio washer. I was told that a repairman would be over and that I was responsible for the service call, parts and labor. Then later, I read on this site about this washer having a service recall that corrects the "Machine Control Assy" failure that causes the F1 code. I called back Whirlpool asking why they never said anything about it when I called earlier. This customer service rep said there was a recall which was stopped (he did not know why) but he would extend my warranty (at no charge) for an additional 3 months starting today which will cover all the repair charges.
    I asked of the repairman when he came, if he was aware that Whirlpool was covering all parts, labor and service call. He said “yes”, prceeded to check the machine and confirmed that it needed a “Control Assy”. He ordered the part from my home (which was delivered to me) and made an appointment to return the following week to install, which he did.
    The machine is now up and running and thanks to contributors to this board, I became aware of Whirlpool taking responsibility for this part failure.
    Oct 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washer stops immediately into cycle
    f1 is the code for primary control failure cod be a bad connection at the primary control under the control console or a faulty primary control if its still under warranty id have a tech look at it
    Jan 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washing Machines Logo
    91 people viewed this question
    Dan Webster
    Dan Webster
    Richard Roth
    Richard Roth
    Mike Cairns
    Mike Cairns
