Question about Refrigerators
Water leak in a Kenmore Refrigerator model 363.9734787
There is standing water in the bottom of the frig under the crisper drawers - we clean it up each day but, it continues to reappear each day - we have cut off the water to the ice maker but, it still continues - please help!
Your refrigerator has atifreeze system that melts the ice formed in the freezer and conducts it to a tray at the bottom where water is evaporated.
The conduct is clogged then the water is inside the refrigerator.
My refrigerator has the same problem, I am looking for a diagram to find out how to unclogg it. I wish you find yours soon. If not a carefull unassamby will help, but I having the refrigerator full it is may be not a good idea. Try to find your diagram first. Or maybe someone will help you with more precise instructions in this forum. Good Luck!
Posted on Sep 15, 2008
Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Oct 27, 2010 | Frigidaire Refrigerators
Water on the bottom of the frig under the crisper
some model's have a drain under criper's ck for drain and clean it . if no drain there its in the back just below the freezer .and can be seen from the back and if found clean it also . this water should be able to get to the pan under frig and not on the bottom of frig .. mm hope this helped .
Oct 21, 2010 | Kenmore Refrigerators
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
I have Kenmore refrigerator,leaks water inside.
Is there an ice maker in the freezer? If so, check all fittings, otherwise, this is condensation, which is VERY common & is actually expected, especially in summer months. There should be a small hole in the bottom, center, under the crisper drawers, make sure that it is not blocked up. The condesation (water) that builds up goes through that hole into a condensation drain pan & gets cooked off by a little boxy thing (golly I forget the correct term & my husband is a refrigeration tech) that warms up or simply evaporates in to the air. The water you see is NORMAL, but your drain may be plugged up, so go have a peek to make sure it's clear, if not, just clear it out & you'll be good to go. Good luck.
Aug 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Inside of frig sweats so much water collecets under crisper draws and leaks out bottom of door
sounds like you need to clean all of the door seals and all contact points on the refrigerator. Do not use alcohol. use a damp rag
Jul 30, 2009 | Kenmore 65802
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
