Question about HP Compaq Business Notebook NX9010
Compaq nx9010 The small Propeller fan behind the above notebook is not moving when i switch on the machine or when i working on the notebook. May i know what is the purpose or function of the fan.
    President:
  • 1,114 Answers
Hi - What you see is the fan that cools the main processor:
It will spin to cool the processor when it gets hot so depending on the surrounding air temperature it may not spin. Usually you can feel it spin up briefly when the machine turns on, try placing your hand over the vent when you switch on. If the laptop seems to be running hot & the fan does not spin then you need to get it looked at as overheating will cause a failure in time.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 06, 2008
    Brigadier General:
  • 5,158 Answers
That fan is important for cooling the laptop's cpu. without it there can be serious damage to the cpu (the brains of the computer). usually it will shut off before there is damage to cpu (thermal shutdown) but not always. have the fan replaced or the dirt and dust cleaned out and perhaps that is all that is stopping it.
Robert
  • HP Master
  • 5,568 Answers
Some laptops have fans controlled by temperature but even then, they normally will be turning at low speed when you first turn the unit on. In a laptop, that small fan may be the only one preventing the premature death of the processor or other hot-running ICs. Desktop PCs have at least two fans; one in the power supply unit, the other mounted atop the microprocessor.
With the power off, use a prod to see if the fan blades will turn easily. Look at it too with a flashlight to see if it is maybe full of dust clumps that you could remove with tweezers. If it seems sticky, it needs to be replaced; they do not generate enough torque to overcome dust bunnies or bearings that drag on the motor shaft.
No microprocessor runs without generating heat, sometimes a whole lot of heat so the fan is necessary to its survival. I wouldn't use the unit until the fan question is resolved.
2 Suggested Answers
informatica
  • 1114 Answers
SOURCE: compaq nx9010 notebook
Hello, this is the inside of your laptop:
So the fan you see at the rear pulls in cool air for the main processor & it exhausts on the left hand side through a grill which you can see. It should spin up on power up of the laptop & you should fell air moving out of this vent. It is most likely temperature controlled so will only come on when the processor gets hot. If the laptop is running hot and the fan is not spinning you need to have it checked.
You can download the service manual on the following link:
nx9010 service manual
Informatica
Posted on Sep 08, 2008
How to dismantle hp nx9010
No problem, rigidarmz!
HP Support > HP Compaq Business NX9010 Notebook PC > Main Support page,
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=321850&lang=en&cc=us
Go down to the subheading -
Resources for HP Compaq nx9010 Notebook PC
Click on Manuals under this subheading.
Scroll down to the black bold subheading -
Service and maintenance information
Click on the file name -
Service Manual
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds, before the first page comes up.
(10 seconds just now using a medium speed DSL connection)
May I ask; anything I can help with?
Post in a Comment.
Regards,
joecoolvette
Oct 14, 2012 | HP Compaq Business Notebook NX9010
Hp pavillon is roasting hot fan working but not cooling any ideas
Put something between the table and the notebook PC so that there is some ventilation. This might cool down the notebook. That is what I do for my Thoshiba laptop. Another option is you can buy something that is made specifically for this purpose. It is a small square shaped plastic sheet like thing which as a few small fans in it. The fan takes it power from usb port. The whole thing is about 7or 8(maybe even lesser) mm thick. Price around $20. Or else buy the smallest fan that runs on 110v (if your normal power is 110V AC) you can get and put it behind the notebook facing outwards. Idea is to exhaust the hot air from the surrounding of the notebook.
Oct 30, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
June 22, 2009 Dear Person, I have an HP-Compaq laptop computer, business model nx9010, s/n CNF3520KL4, with a failed hard drive. I am unable to remove the drive. I have removed the three (3) visible screws...
http://www.karlin.mff.cuni.cz/~motl/hp-keyboard/manual4700.pdf
PAGE 39
1. Unplug the AC adapter, if present, and then remove the battery.
2. On the bottom of the notebook, remove the hard disk drive rubber screw plugs and
M2.5×6.0mm screws. (The number of plugs and screws varies by model).
3. Carefully pull the hard disk drive out of the notebook.
4. Remove the four M3.0×4.0mm screws from the hard disk drive and hard disk drive tray,
and then lift the drive out of the tray.
5. Remove the connector bar from the hard disk drive.
The manual does have little picture to help you. The link above is to download the service manual.
Jun 23, 2009 | HP Compaq Business Notebook NX9010
HP Compaq nx9010 CD drive replacement
You are correct.
The screws for the dvd drive is under the keyboard.
there should be 2 tabs one above the f4 and the other above f12 take a regular head screw driver put it where those tabs are and gently pull down towards the touchpad and the keyboard should come up easily.
Now under that keyboard in the center you will see a opening and inside that opening you will see 1 philip head screw remove that by turning counter clockwise.
Right below where you removed that screw you will see another opening which has another philps head screw in it.
Remove that screw counter clockwise and the dvd rom should pull straight out with ease.
To put it back together just reverse the steps.
If you need further assistance do not hesitate to ask.
Dec 03, 2008 | HP Compaq Business Notebook NX9010
Want to increase memory above 1 gig. compaq nx9010
You may have incompatible memory module. Just put in one memory module in at a time to see if it boots up, this will determine which module was not compatible.
Nov 15, 2008 | HP Compaq nx9010
Mini fan behind the notebook Compaq nx9010
i took mine apart and it looks like when you use vid out, the yellow thing, that chip will require cooling as does everything on the laptop i think the key board has a frikin' fan anyway, i have not tried this port yet so this is just a hacked guess
Sep 07, 2008 | HP Compaq Business Notebook NX9010
Compaq nx9010 notebook
Informatica
Monitar drivers
Here is general download page for your laptop, you will also need to install network driver and audio drivers :
HP Compaq nx9010 Notebook PC - Download drivers
here is video driver :
» Driver - Graphics » Driver - Graphics - Intel
Try both, as 9010 is built in two different versions.
Please vote the solution.
Many thanks.
Aug 15, 2008 | HP Compaq Business Notebook NX9010
1024mb Ram for compaq nx9010
Yes. Max is 1 GB PC 2100 DDR 266 or higher
I have this notebook, and I got my memory at www.crucial.com
Nov 20, 2007 | HP Compaq Business Notebook NX9010
HP Compaq Business Notebook NX9010 Logo
1,681 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
