Question about Panasonic TH-50PV30 50 in. Plasma Television
Panasonic TH-50PV30 Please can you suggest a reason why my TV keeps turning its self off. It is intermitent. Sometimes it stays on for 10 minutes other times it`s only 5 minutes or even seconds. Any help will be great.
  • sergio2k67 Sep 15, 2008
    yes, i've same problem.
    when it's cold, for exp, in the morning, it start normaly, but when i' try to start after 5 minuts, i've a red led that blink 4 times and the remote control command no whork.
    I would try to resoldier all alimentition circuit like told in past comment.
    i will you know.
    Sorry for my english.
    better days.
    Sergio. (Capri Island)
    Novelist:
    Champion:
  • 277 Answers
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Posted on Dec 22, 2005
TV goes onto sleep mode while watching and cannot be switched on with the remote
Hi well whenever this happens it is always the micro controlling the unit, that or some fault that affects the main controller and "Glitches" it, sometimes it can be caused by a damaged power supply, and the "Spikes" get through to the processor and cause it to do what you describe.
Please find below a link so you can download a copy of the service manual, should you wish to DIY?
However should you not wish to DIY, and I do NOT recommend it, my advise is to contact a local or head office from Panasonic, and ask them for a referral to an authorised service center, now ,make contact here and ask for a service call, or better yet, take the unit to the repair place, in any event when in face to face contact ONLY ask for a "Quote" this way you can be appraised of what's wrong and prospective costings, and you can than at the least make up your mind as to repair or replace? I say this as more and more in my shop i find customers are these days preferring to replace rather than repair, and put any monies that would have been spent on repairs be put towards a new unit, with a full warranty.
http://www.givemefile.net/smanuals/tv/panasonic/th-50pv30.html
Oct 09, 2011 | Panasonic TH-50PV30 50 in. Plasma...
How do you remove the stand from a panasonic TH-50PV30 50 inch type with 3 levvels of storage shelving. Thanks.
Never owned the this TV, but from what I can tell the outside edges on either side should have a series of screw holes. Even if you can't see the actual screws, there are philips head and there are in the bottom of those 4 or 6 holes. Take those out to get the TV off the stand.
Those may also be covers for a less complex connect to the spot where the additional speakers normal mount. Either way, remove still starts there.
Apr 27, 2011 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic Plasma TV won't turn on
my television will not power on at all no lights no anything, Worked fine the day before
May 21, 2010 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-42PX60U Turns On/Off by itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 30, 2017 | Panasonic TH-50PV30 50 in. Plasma...
Intermittent turning itself off
check your setup menu and make sure that turn off timer is off
here is instruction below on your tv
hope it works
panasonic.com.au/content/library/files/F000518.pdf
Oct 27, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-50PV30
Make sure the power supply cable is tightly plug-in, the one in the back of the TV. This fixed my problem.
Jun 06, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Oct 21, 2005 | Panasonic TH-50PV30 50 in. Plasma...
Panasonic TH-50PV30 50 in. Plasma Television Logo
292 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
