Question about Dynex Keyboard/Optical Mouse DX-CKB102
Right click menu
When i right click on anything i get a circle menu over the spot i clicked on and i can't get rid of it and return the right click button back to it's original function
Try going into windows Control Panel/Mouse and see if the buttons are set correctly.
Posted on Sep 06, 2008
How to get rid of my start on goole chrome
I'm not sure what you mean by "my start"? If it's a program delete it. If it's malware run MALWAREBYTES at :http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK TRIAL PRO Version, you want the freeware. RUN A FULL SCAM, DELETE ALL RESULTS. ALSO, Download CCLEANER at : http://www.filehippo.com/download_ccleaner/. Use this to clean the junk from your system. IN TOOLS,STARTUP, Disable ALL unnessary Startup Programs. Delete ALL TOOLBARS from broswers , they kill you broswer speed.
Dec 10, 2012 | Dell Inspiron 1525 Laptop
Tip
How to create motion across the screen?
Step 1
Create a small circle to the left in the Stage area. Do this by selecting the circle tool from the left toolbar. Draw the circle in the Stage area.
Step 2
Select the Arrow tool from the left toolbar. Double-click on the circle to select it.
Step 3
Now we have to convert the circle to a symbol. When the circle is converted to a symbol we can create instances of the circle. From the top menu choose Modify > Convert to Symbol. Name the symbol "Ball", and select OK.
Step 4
Go to Frame 10 in the Timeline. Do this by clicking the gray field below 10. Then right click in this field. Choose Insert Keyframe. Keyframes appear as circles in a frame. This operation duplicates the image.
Note: A keyframe specifies changes in an animation. You create keyframes at important points in the Timeline and let Flash create the frames in between.
Step 5
Select the circle and move it to the right a couple of inches.
Step 6
Click on the Timeline any place between Frame 1 and Frame 10. Then right click and choose Create Motion Tween.
Step 7
Choose Control > Test Movie from the top menu to test your Flash movie.
on Aug 11, 2008 | Adobe Flash® CS3 Professional Full Version...
Owon the emachine t3256 I don't have a emachine folder or line on the all programs list
1) Right-click on Start
2) Left-click on Properties in the drop down list.
3) Left-click on the Start Menu tab. (Unless it automatically opens to the Start Menu tab)
4) Make sure there is a Green dot in the small circle, to the left of Start menu. If not left-click in the small circle to the left of Start menu.
Go below to the right, and click on Apply.
Now go below to the left, and click on OK.
Regards,
joecoolvette
Oct 25, 2012 | E-Machines eMachines Desktop PC
How do you put the computer in safe mode on a HP pavillion?
If I remember correctly, for Windows XP:
Click on 'Start' at the bottom left of your screen
Click on 'Run' - should be on the right side of the Start menu towards the bottom.
A box will appear at the bottom of the 'Start' menu. Enter "msconfig" (without quotation marks), and press the Return/Enter Key.
A new window will open with several tabs. Click on the BOOT.INI tab to open that, and click in the square box first on list by /SAFEBOOT. There are three variants of safe mode. For now, choose 'Minimal' (click in the circle by that word). Now move to bottom right of the MSCONFIG window and click on the 'OK' button. Now the window will close, but next time you Restart/Start your computer it will be in Safe Mode (font will different, and it will say 'Safe Mode' at the four corners of the screen).
12.April.2014
Aug 30, 2012 | HP Pavillion s7420n PC Desktop
How to check a disk from my computer
click start, then select accessories from the programs menu. Right click on command promp and run as administrator and type : chkdsk /f
Jun 27, 2012 | Acer Aspire One AOD2501604 Netbook
White spots..
Dell Latitude D620 Laptop (Latitude-C620) PC Notebook
take alook there and see if you can tell what to do.
Then I often find that is good to click on START-control panel once there click on display. There you can control your sisplaay and hopefully get rid of the white spots.
all the best
kollagunn
Feb 21, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
My audio stopped working after I got a virus, I got rid of the virus and wiped the compter clean. The whole thing runs like new except my realtek high def audio controller says error code 10. I've...
Try installing it manually. Right click computer icon in desktop or start menu -->choose manage --> go to Device Manager --> Find the Audio device that has a Exclamation mark, Right click on the icon and choose update drive. A Hardware update wizard will pop-up tick the last circle that says no, not at this time ->install from a list of specific location ->Search for best driver in these locations tick the include this location in search box and then click Browse.. Choose where the Audio driver is located (either the driver CD or in your computer) and click next.
Sep 13, 2011 | Toshiba (4CH-VOUT) Sound Card
There are some items in my "favorites" list that I no longer use and would like to delete them. How do I do it?
Click on Favorites.
Just go down to the one(s) you want to delete and RIGHT click.
There is a Delete menu item. Just click it. You will be ask to confirm it.
Thanks for using Fixya.
Aug 07, 2011 | Computers & Internet
I have a 3000 deminsion Dell. I can't get on the net or anything all my icons arfe gone on the bottom of the screen. even my virus protection icon avira. Is therfe a way to download something from my...
Click "start", then "control panel". Find and right click on "Toolbar and Start menu", and open. In the window you want check marks next to "lock toolbar", "keep the taskbar on top of other windows",and, "show quick launch" then click apply, then ok. Now click on the "start menu" tab and make sure there is a dot in the circle next to start menu, click apply, then ok.Now click on the "toolbars" tab and make sure there are check marks next to "desktop" and "start menu", click apply, then ok. Exit that and restart. Your icons shold work but if for some reason they don't, you shpuld be able to click "start" and find an Internet Expolrer icon in you box. You can also accsess your programs by clicking on start, click on "all programs", scroll to the program you want, then double or right click on to open.
Apr 07, 2011 | Dell Dimension 3000 PC Desktop
Code 507 with circle as soon as i switch it on wont let me do anything else
Error 507 appears when any subsequent attempts to perform an Application Load or upgrading the software
on the BlackBerry smartphone are unsuccessful
Solution :
1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2. Click on the Application Loader icon.
3. Click Update Software.
4. Type your BlackBerry smartphone password (if prompted) and click OK.
5. Select Options under the Device software options section.
6. Select the check boxes next to the names of the applications you want to install.
7. Click Settings, and remove the check mark from the check box for Back up device data automatically during the installation process.
8. Click OK.
9. Click Next > Finish.
10. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
If it shows the same error then please visit to the nearest Service centre.
Oct 31, 2009 | RIM BlackBerry 7290
Computers & Internet Logo
52 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
