Question about Panasonic PT-53WX42 53" Rear Projection Television
TV Turns off on its own ?
When I press the power button and the TV begins to power up, it will click and then turn back off before projecting a screen. The power button light will then blink and no button will cause anything to happen. The TV will not turn on and the remote does not work either. The TV is on a power surge protector and all other electronics attached are working fine. All other connections seem to be good. If I unplug the TV and try again, the process will repeat. The trouble shooting guide doesnt say anything for this type of trouble and the manual doesnt say there is some sort of pretection mechanisim going on... What could be the problem? Thanks
  • dion ead Jan 22, 2008
    I in fact had 2 convergence IC's bad. Parts were 30 bucks a piece and labor was 660....Freekin ridiculous.... They even tied to charge me 100 a piece for the parts I could get form Panasonic directly at 30 a piece... Crooks ..... I paid the 30 and had them repair it, and promptly sold the TV.... Traded for a 1080P Samy... Couldnt be happier...
Where are the fuses, diodes or solder joints located at inside the tv?
Posted on Jan 22, 2008
    Problem Solver:
  • 10 Answers
I don't think the above issues cause from leaky diode nor bad solder joint.
I belive the fylback need to be change,
Posted on Dec 13, 2007
  • John Brown
    John Brown Dec 24, 2007
    Check the convengence IC's one of them could be bad.
    Good luck.
    Novelist:
    Champion:
  • 277 Answers
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Posted on Dec 22, 2005
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
TV will not turn on-- clicking noise in the back
The power pack the the power cord goes into has gone bad and needs replaced, see manufacturer for service or parts.
Nov 15, 2007 | Panasonic PT-50LC13 50" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Power
same problem here
Dec 20, 2007 | Pioneer SD-P50A3-K TV
Mitsu. VS-50707 problems
12 = No error detected, check power supply.
check all your voltage coming out of the power supply and check the fuses.
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Sound, but no picture
Had the same thing today. Iwas playing with the auto demonstration of on screen displays. Press and hold the power button (5 seconds) on the TV. The auto display will play. Press the power button again (TV will go off). Turn power on again. you should now have the picture back
Nov 14, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
202 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
