Question about Kenmore 16919 Built-in Dishwasher
Dishwasher stops after filling
I have a Kenmore model 16949 Ultra III. It fills, then quits showing error codes E6, E7 of E8.
What is this related to and how do I fix it?
5 Suggested Answers
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
rickzilla
  • 706 Answers
SOURCE: Kenmore Ultra Wash III Dishwasher will not drain properly
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Posted on Aug 26, 2008
SOURCE: Kenmore ultra wash dishwasher control lock light flashing
Hi jabberr216,
I'm Harvey the Master Plumber.
Your question is: You have an older model Kenmore ultra wash dishwasher model #15805890. The control lock light is flashing. No buttons are working. The dishwasher does not turn on. Any solutions?
Sure! Someone must have activated the lock. It is next to either the 'air dry' or 'heated dry' button.
Press and hold that button till the lock light goes out. About 6 seconds. That's it. It turns on the same way.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 03, 2008
leroyal
  • 2120 Answers
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Posted on Jan 06, 2009
gisvc
  • 40 Answers
SOURCE: decible level for a Kenmore model 16625691 ultra dishwasher
HI,
ACCORDING TO SEARS TECH SERVICE THE AVERAGE DECIBLE READING IS 53.5 DECIBELS
HOPE THIS HELPS. THIS IS ONE OF THE QUIETEST MODELS IN THE CLASS OFFERED BY SEARS.
Posted on Mar 30, 2009
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
How do I get error code f2e2 off my dishwasher?
"F2 - A water leak, which if detected will stop water from entering the dishwasher via the inlet valve. You will probably experience the dishwasher not filling properly during a cycle. Possibly caused by a faulty water level indicator, you can also try cleaning the filters and drain if you notice a lot of standing water remaining in the dishwasher basin."
"Look in the bottom of the unit. Something has it stuck, like food."
sorry if this doens't solve your problem. This is what turned up with your keywords in a quick search engine query.
Sep 18, 2014 | Kenmore Dishwashers
Getting error code E6 on our Fishare and Paykel dishwasher DW60CDX1. Unsure how old it is, and if it's worth repairing?
E6 is a spill over alarm it basically means it is filling with to much water, it sounds like the water inlet valve is starting to jam open, tell me if you open the door does the water keep coming in? if it does the valve is jammed open which is a relatively cheap fix, if it stops when the door is opened it is likely a pressure switch or flow meter problem or possibly a control board.
Aug 28, 2014 | Fisher and Paykel Dishwashers
E7 error printer hp laserjet m 1136 mfp
try this
E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support.
Aug 23, 2014 | Office Equipment & Supplies
Eurovox codes
new codes for 5a 01 north east
e7 d3 69 2e 6f 38 ea 78
a1 38 06 29 24 29 8d 2b
recoded mine @1800 29/01/09
happy viewing.
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Kenmore ultra quits working pf and e8 light come on
If your pf light comes on that means that your outdoors fuse needs to be replaced. The same thing happened to me and I bought another dishwasher for the same proble to occur. I don't know if it's to late but the only thing wrong is your fuse is blown. Good luck!!!!!
Nov 23, 2008 | Kenmore 13599 / 13594 / 13592 Built-in...
Aug 26, 2008 | Dishwashers
Open Questions:
See all Kenmore 16919 Built-in Dishwasher Questions
Kenmore 16919 Built-in Dishwasher Logo
51 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
