Question about Pioneer Audio Players & Recorders
I need to hook up a set of Bose 901 direct reflecting speakers to my pioneer VSX-94TXH receiver. I need to hook it up using the Tap In/ Tape Out modeā€¦the issue is I am not sure how to set the receiver to the correct mode so that I can control the Bose amp.
4 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Posted on Feb 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: Bose 901 Active EQ Loop
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to recieve its Active Equalization and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs.
The good news. I have a setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W).
Run the dbx and BSR in tandem with each through the tape monitor loop on the receiver but be advised you can only use them on analog source stero material. However, you can still employ the various DSP options to spread the sound around the room.
At my PC workstation across the room I have a stack of analog processors and sources including dbx 3bx-ds, dbx 120x-ds, BSR Spatial Enhancer, BBE 462 Sonic Maximizer, SS-525x EQ, Carver C-9, dbx-224x, JVC cassette deck, Dual 1249 Turntable running through a Garrard MRM-101 Preamp, Pioneer PDR-509 CD Recorder and the Media Center PC stereo analog channels all running through a dbx 400x Program Route Selector (a godsend) which is attached to my ONE TAPE MONITOR on my Pioneer VSX-36TX Receiver. Of course, I have some of my analog processors running in tandem, too, since the 224x only has three processor and three tape loops.
For listening/recording anything 2-channel analog I engage the stack through the Tape Monitor. For everything else I turn the Tape Monitor off. The nice thing about the stack being separate is that I can doodle with recording and use headphones while the TV/DVD/Blu-Ray do something else.
Posted on Apr 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do I connect my Bose 901 to my Pioneer
The use of 901's in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor.
That is because if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. However, you can still draw the Front Left and Right signals out of any Pre-Out (with a Y-cable set, looping the Pre Out directly back to the Main In) or Tape Out jacks (remembering to NEVER activate that monitor on the receiver), go into the Active EQ's Amplifier Connections; then Out of the EQ's Amplifier Connection to a separate amp and attach the 901's to that amp. This way you won't introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed. This is how mine is wired.
Come to think of it, you could still have conventional Front L&R speakers on the AV Receiver, but why? Maybe one would prefer the 901's for music and some other speakers for surround. Level matching with the 901's to conventional front speakers would only be possible if the separate amp has its own volume, but it would work. Maybe I'll try it someday. None of my current amps has a volume control.
Posted on Nov 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
Connect pioneer vsx-9700s receiver to tech.equalizer??
If there is no rca connection on the back labeled something like "external processor" then it could probably go through a tape loop. At least that's the way it used to be done last millenia. ;)
Jan 18, 2013 | Bose 901 VI Main / Stereo Speaker
I have a Bose 901 Series VI speaker system & have recently purchased a Pioneer VSX-1020-K AV Receiver. How do I connect the 901's EQ to this amp. I believe the only option is the CDR/TAPE IN/OUT...
This receiver has no pre-amp outs to drive the required separate amp the 901's need for you to continue to have multichannel digital audio. The reason: activation of a tape loop disables digital inputs. But they DID give you Front Height. Oh boy.
Sep 15, 2010 | Bose 901 VI Main / Stereo Speaker
Pioneer vsx 1020 K receiver. I connected the bose 901 eq to the tape in and tape out but it doesn.t seem to be compatible.
It would be compatible if you ONLY listened to stereo ANALOG sources on ONLY Bose 901's. Engaging any device in a tape loop automatically disconnects digital sources. Bose Active EQ is not intended for anything BUT Bose 901's. The sub could be destroyed by it.
Lacking appropriate Front Left and Right volume-controllable pre-outs on the 1020k, you can't use the 901's for multichannel or digital source material unless you accept a severe compromise and get a separate amp for the 901's borrow mixed-down stereo from the Pioneer's Tape Out, run it through the Active EQ to the new amp and manually manage the external amp's volume.
You need Front Pre-outs.
Jul 20, 2010 | Bose 901 VI Main / Stereo Speaker
I have a pair of bose 901, v1 I have a old pioneer vsx 5300
Not knowing anything about your specific amplifier or if it correctly configured for the 901 Active Eq, the first thing I would say is these are designed for analog stereo sources ONLY and a multichannel digital-capable receiver will NOT work properly with any devcie in a Tape loop.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
May 14, 2010 | Bose 901 VI Main / Stereo Speaker
How to install bose 901 eq to my pioneer vsx-1019ah-k
This works for all models of AV receivers when you want 901's as Front L&R speakers..
Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
Nov 04, 2009 | Pioneer VSX-1019AHK A/V receiver
Pioneer vsx 90txv and bose EQ
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Feb 01, 2009 | Pioneer VSX-90TXV Receiver
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Connecting Bose 901 Series VI Direct Reflecting Speakers to JVC RX-8020VBK Receiver
in order to make those speakers sound good (if they can sound good at all) you need to use equalizer box witch came with them. If your receiver does not have tape monitor loop or preamp to amp jumpers you can not use those speakers. To be honest you do not loose much... none of this stuff is any good (sorry for bad news), but if you like those speakers (I know they have big fans, even if in HI-FI world, they not consider as good) you have to change you receiver. Dariusz
Feb 13, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
