Question about Muvee Technologies autoProducer 4 for PC
No original Soundtrack in Muvee 6.1
After moving the slide bar for the soundtrack level setting to maximum, I still have no original footage soundtrack. I have moved all other slide bars to minimum. Still awaiting response from Muvee technical support.
  • 1 more comment
  • Anonymous Sep 16, 2008
    Same problem here. Mpeg files audio track worked fine as separate files, but when put into Muvee Autoproducer the sound track was gone. Happens both when burning DVD or simply saving a wmv file.
  • mikevbk Dec 24, 2008
    Trying to import video clips from my handcam and there's no audio associated with the video file. Pretty lame. When I downloaded Muvee as a trial it worked, then when I purchased the softward it no longer kept the audio.
  • Anonymous Jan 16, 2009
    I have the same problem. Have 6.1 and no audio after moving the audo bar to max for the Video Soundtrack. Still no audio
Is the soundtrack for The Get Down all original and recorded only for the Netflix show?
The Get Down (Original Soundtrack from the Netflix Original Series) is the official soundtrack for the first part of the first season of the TV series The Get Down featuring various artists, released by RCA Records on August 12, 2016
The Get Down soundtrack
Aug 30, 2016 | Movies
Serial number soundtrack pro
Please purchase the product and support its developers in order to obtain the serial number.
Dec 12, 2012 | Apple Soundtrack Pro for Mac
How do you add the music to the slide show?
Dear annettesamto
First do the photos. When you have finished that, click on the "Next" button at the bottom of the window. Now look for your music files by clicking on the "Select Audio Files" button in the "Soundtrack" section. For example, go to "My Documents" and then select the "My Music" folder and click on "Open". Select the music file you want and once again click on "Open". The track you have chosen should now appear in the white area in the "Soundtrack" section. Repeat this to choose more music tracks until you are satisfied with your selection. To delete any tracks from the list, select it in the "Soundtrack" section and then click on the little dustbin to the right and just above the white area where the names of the music tracks are.
Hint: Try to get the combined length of all your music tracks ("Total audio time") close to the "Duration of Slide Show". Then decide how long (in seconds) you want every photo to be displayed before the slide show moves on to the next photo. All your photos will be displayed for the same amount of seconds. In the "Duration" section, at "Set Duration", type in the amount of seconds you would roughly want your photos to be displayed for (for example 8 seconds). If the "Duration of Slide Show" and "Total audio time" is the same or very close, you can ignore the part where it says "Auto-Fit to Soundtrack". However, if the difference is several seconds or more, click on "Auto-Fit to Soundtrack". This will ensure that your slide show (photos) ends when the music ends. It means that your photos may now be displayed for slightly less or more seconds than the amount you indicated, but at least the soundtrack and the photos will end together.
When you are satisfied with your soundtrack, click on "Finish" at the bottom of the window. If the computer asks you if you want to replace an existing file, click on "Yes". The soundtrack window dissapears. Now click on "File" at the top left of the window and choose "Save Project".
You can listen to your soundtrack by clicking on tab 3 ("Produce") and then on the "Enter" button on the remote control.
You should be aware that some music files may not work with SlideShow Expressions, particularly some files that have been downloaded from the internet, for example through iTunes. This has to do with copy-protection and causes some tracks not to play properly. As a rule, though, mp3 files should work fine, as well as tracks ripped from CDs, like wma files. The User Guide gives a list of all the supported music files. The User Guide is on the install disc. To find it, insert your install disc and click on the relevant link that appears, or you can go to "My Computer", right-click on the CD/DVD drive and click on "Explore" to look for it on the install disc; it is a pdf file.
I hope this was helpful. The best of luck to you.
Hendrik Uys
Oct 07, 2012 | Individual SlideShow Expressions
I cannon figure out how to add music from my computer to the slide show....please help me....I have 5 songs on my desktop and I cannot seem to figure out how to get them to slideshow...
Best jbannon257
There could be a number of reasons why you're having trouble adding music files to your slide shows. First I'll lay out the procedure and afterwards I'll give some hints / a link to individualsoftware.com where problems with audio files are discussed.
The procedure (adding music files using SlideShow Expressions):
The programme opens and you are automatically in tab 1: "Add Media".
Click on "Create New Slide Show". Click on "Add Photos"; tell the programme where the photos are, select them, insert them, change their positions if necessary.
Now:
1. Click on "Next" at the bottom of the screen.
2. At "Soundtrack", click "Select Audio Files", then tell the programme where the music files are located on your computer, click to highlight a specific music file, click on "Open". The music file you selected now appears in the Soundtrack window. Repeat this until all the music files you want appear in the Soundtrack window. (You can delete any of them by clicking to highlight any specific file and then click on the little rubbish can icon.) As you go along, the total audio time for the slide show / chapter is displayed as well as the "Duration of Slide Show".
3. In the "Duration" section, you have the option to set the length of time you want per slide (seconds) - usually 8 to 10 seconds is best. (All your slides will follow this instruction; you can't set the duration of individual slides to a different time.) At "Auto-Fit to Soundtrack", you alter the duration of the slides to fit the length of the soundtrack. (This cancels out the previous seconds-per slide setting.) You must therefore choose music tracks that, when added together, will approximately span the whole length of the slide show and then you can fine-tune this by clicking the "Auto-Fit to Soundtrack" option.
4. When you are satisfied with your choice of music tracks and the length of your slide show, click on "Finish".
Issues with music files when using SlideShow Expressions
A.
According to the User Guide (section 3-3) - included on the install disc as a pdf file - the supported audio formats are: mp3, wma, wav, ra. Make sure that your computer also meets all of the requirements (on the box).
B.
Photo & Video Expressions is not compatible with audio files that have been protected by Digital Rights Management (DRM) functionality. Most audio files purchased online through Internet music retailers like iTunes, Urge, or Rhapsody are encrypted with some form of DRM. Similarly, audio files that have been extracted from a CD or DVD (the process known as "ripping") using certain media applications (iTunes, Windows Media Player, etc.) often have default settings that encrypt the files extracted.
There is no way to used DRM audio files purchased from online music retailers with Photo & Video Expressions. However, if you want to used music and audio files that you have extracted from your CD collection, then all you have to do is change the ripping setting in your media application before you extract the files to your computer.
Go to the following site to read about how to change your ripping settings:
http://www.individualsoftware.com/support/frequently_asked_questions.html
Type your question OR (below):
"Photo & Video Creativity": choose "SlideShow Expressions" from drop-down menu, click "Go".
A window appears with options on problems, e.g. "Why aren't my audio files showing?"; "Why won't my music files work?" Click to read.
The best of luck to you. From: 11407336.
PS. Try individualsoftware.com
May 30, 2011 | Individual SlideShow Expressions
I have a video of a sailing ship entering harbour. The sound is not very good and I would like to change this to a suitable musical track.
If you have a PC with windows movie maker installed export your footage via USB2 into your video folder on PC then drag & drop or import your video into movie maker.Rip a CD music track in media player & drag & drop or import into movie maker.
turn down volume of original sound & replace with new soundtrack then publish the movie in format of your choice.
If you get stuck read movie makers help folder.
Aug 13, 2010 | Panasonic SDR-H80 Hard Drive Camcorder
I have downloaded soundtrack albums to the player and it mixes up all the tracks. the player is set non-shuffle. I am trying to listen to a particular soundtrack with all the tracks in order and it won't...
Usually this is because the tracks on a soundtrack album are attributed to different artists. Your player is probably ordering them by artist in alphabetical order. You might be able to tell it to order them by track number instead, or you might need to re-write the ID3 tags on the files, in a program like iTunes. It's easy to do. Once in iTunes, highlight the album and right click, go to info, and tell it that all of the songs are written by the same person. I hope this helps you! :)
Jul 27, 2010 | Insignia NS2V17R MP3 Player
I made a powerpoint presentation with PP2003, first added 6 slides, then added another 20. When I add music to the presentation, the music stops at the 6th slide. HELP!
To make a sound continue through multiple or all slides, follow these steps:
  • Go to the slide where you want to begin your audio track (defaulted as the first slide), and select Insert -> Movies and Sounds -> Sound from File to insert the sound.
  • After you click OK, you can see a message pop up asking how you want the sound to start in slide shows. Click Automatically.
  • Select Slide Show ->Custom Animation to enter the Custom Animation pane. Your soundtrack is listed below in the pane.
  • In the drop-down list of the sound, choose Effect Options. Then the Play Sound interface appears. In the Effect tab, click the radio button beside Stop Playing After XXX slides (which indicates how many slides you want this song to play across) to enter the number of slides you intend to add. For example, you can enter a number from 1 to 999 for this field. Then the sound will play throughout the specified slides.
  • Next, check the settings in the Timing tab. To play automatically, you can set to Start After Previous with a 0-second delay. Click OK to exit the dialog box.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slideshow if you don't want it appear.
Now you can play the soundtrack from the very beginning to the end of your slideshow.
Source:
http://www.dvd-ppt-slideshow.com/powerpoint-knowledge/sound-across-slides.html
Jan 16, 2010 | Microsoft PowerPoint 2003 Student &...
How do you record without sound
There does not appear to be any provision on the camcorder menu, to mute the audio.
As an alternative, I would recommend you connect the camcorder to your computer or laptop (via firewire if possible) and transfer the footage onto your computer's hard drive.
You can then use your computer's Movie Maker application to edit the footage - here you can either remove the audio track, or overlay your new audio soundtrack.
Good luck !
"if this has helped you, please rate this solution"
Dec 03, 2009 | JVC GZ-MG330 HDD Camcorder
Computers & Internet Logo
326 people viewed this question
Top Muvee Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Muvee Technologies Computer and Internet Expert? Answer questions, earn points and help others
