go to setting and turn off automatic updates, I think toshiba has a program for their updates I think its called catalyst disable the updates there too https://www.6ya.com/mr.mike good luck
Im guessing XP and if you have the CD do whats called a repair install. Choose the upgrade option then install it, this will not harm any of your programs at all you will just have to do all the windows updates when its finished. Cheers and please vote
Your computer freezes due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM. 2. Click Start ' Run. 3. Type SFC/ ScanNow and press ENTER. 4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout. 2. Click Registry Cleaner tab. 3. Click Start Scan. 4. The registry scan will start. Wait till it is finished. 5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp. 2. Follow the instructions on your screen
It could of course be hardware related, but unless you are running sufficient and updated malware protection, it could be result of junk installed from elsewhere.
What programs are installed on the machine? there may be a file that's conflicting with one of the updates. You may leave automatic updates turned off. Looking for the culprit will require and will be easier if a tech will check the computer onsite or thru remote access.
The file deletion may not be the issue. You may have some sort of virus or spyware interfering with the system boot. You may have driver or setting that is not fully resolved from an update. My initial suggestion for a solution would be to restart in Safe Mode, wait for the computer to fully load all of the basic drivers there, then just restart in normal mode and see if that fixes it. The next suggestion is to restart in Safe Mode with the Administrator account and load an earlier System Restore point. After that, it gets complicated.
when start your computer press the f8 button its show the safemode
click the safemode and open the windows in a safemode when your
computer start then open start>all program
files>accessory>system tools> system restore> open it and
choose the date when your windows is working with sp2 after that click
next and finish it your pc take a reboot then its restore your sp3 will
be remove from your pc
data recovery is possible.... the more you had to the computer after a restore or format hinders the recovery of data.
are you using a legal copy of xp ?
Robert
