Question about Kitchen Ranges
Jenn air jgd8130adb gas cooktop--- none of the 4 burners will spark. gas flows fine
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
SOURCE: Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Posted on Jul 07, 2008
  • 217 Answers
SOURCE: Igniters do not spark on one side of cooktop
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Posted on Jul 11, 2008
SOURCE: Jenn Air Grill - Gas flow from one valve
I have the same problem. The middle and the right burners will work, but if I light the left side (3rd burner) all 3 go out. pressure is reduced to zero.
Posted on Oct 12, 2008
SOURCE: GE profile gas range: Gas burners don't work
Used toothpick to unclock gas output and worked great.
Posted on Jan 23, 2009
How do I replace the spark module on the jenn air JGD8130ADB cook top?
It is beside the thermocoupler , Buy new one .
Remove old one .
Install new one .
Oct 28, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
All 4 Igniters keep firing after the burner is lit.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
ghhdf
May 02, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn air downdraft cooktop. We had a new Jenn Air
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
May 02, 2010 | Jenn-Air Freezers
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
Jenn Air Cooktop Burners Won't Ignite
The orifices may be dirty. They can usually be cleaned out with a safety pin.
Sep 20, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Kitchen Ranges Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
