Question about Equator EZ 3600 CEE Front Load Washer / Dryer
How to get your EZ to start drying again
Hi Intrakor, go to http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3600CEE_EZ3600C_EZ2500C_EZ1500/Service_Manual.pdf on page 17-18 it shows you the impeller.  it is tricky to reach (specifically getting to the screws holding it in) but once you get it out clean it thoroughly (even if it seems that there's not much build up of lint) and your dryer should start working again perfectly.  i've had to clean mine once every 6mos or so.  hope this helps.
  • usa110876 Sep 11, 2008
    doenst dry clothes at all, i tried to find the impeler (i have the pic) but not sure where is located, pls help me.
    tks
    Anny
Thanks, snwbrdr! it's working much better now! thanks. damn ... that thang was DIRTY!
Posted on Sep 09, 2008
Manual
http://www.retrevo.com/support/Equator-EZ3600CEE-Washers-manual/id/20332bh434/t/2/
this website has 3 manuals for the EZ3600CEE to download: user guide, service manual -(covers problems with solutions and repair procedures), and hardware guide.
Aug 16, 2010 | Equator EZ 3600 CEE Front Load Washer /...
The machine is not drying, and is not heating the water
The 2 thermostats and the temperature sensor may have to be replaced. You may contact appliance desk technical support for proper troubleshooting and then order the parts required from them itself.
You can find their contact information on their website - www.appliancedesk.com
Feb 11, 2010 | Equator EZ 3612 CEE Front Load...
Where can I buy a new belt to my equator EZ 3600 C / B ?
You can purchase a new belt for your EZ3600C from appliance desk through their website www.appliancedesk.com and then click on shop parts.
Sep 26, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Equator EZ 3600 will not start at all.
If you are still looking for a solution to this:
it is always advisable to make sure that the machine has been installed as per the information stated in the owners manual.
On the other hand before calling a repair person you may first want to call Equator customer service which is handled by Appliance Desk, you can get their contact information on www.appliancedesk.com and do the trouble shooting with their technical department first and if they advise for you to get a repair person then and then only go for one.
Jun 04, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Door handle for Equator EZ 1612 V
If you are still waiting for this part you can purchase it from www.appliancedesk.com click on shop parts.
Jan 23, 2009 | Equator EZ 1612 V Front Load Washer /...
Combo Washer-dryer
Just for your information, you can call Appliance Desk and speak to their technical support to understand the wiring diagram.
You can download the manuals from their website as well which www.appliancedesk.com
Jun 29, 2008 | Equator EZ 3710 CEE / W Ventless...
Dryer cycle doesn't dry on Equator EZ3600 CEE
It's lint stuck in the dryer that drastically lowers the efficiency.
From another site I found the solution:
1. UNPLUG UNIT
2, remove 4 screws top back edge of top panel and lift off panel.
3. blower will be toward the right rear of unit. To save a hassle later, take a sharp object and scrib an index mark across where the blower meets the plenum, it will help you line it up later.
4. there are four 7mm bolt-head screws holding the blower and blower motor onto the heater plenum. One of the screw is almost impossible to see, but there are 4. I used a "flex-shaft" socket to get them out. This can be a real PITA.
5. carefully lift blower motor out of plenum. You will probably need to shove the whole tub unit to the left to get clearence. IF YOU OPT TO DISCONNECT THE BLOWER WIRES MAKE A DIAGRAM OF WHERE THEY CONNECT!!
6. I usually use a thin knife to scrape each of the vanes on the blower. Then vac everything out and use your hand to check for smutz in the plenum.
7. THE FAN ONLY FITS ONE WAY ON THE PLENUM. be sure to test fit to see if all the holes line up.
8. When motor is back in place, spin the little cooling fan on top of motor to make sure it's not binding. I usually test the unit by plugging it in and starting dryer to make see it runs.
9. Put top of unit back in place.
Jun 26, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Handle
I order mine online from appliancedesk.com. I have one ordered now. It is on backorder. When you install new, be sure to mark position of door inserts, just in case they separate and you have to figure out how to reposition them.
Apr 09, 2008 | Equator EZ 3612 CEE Front Load...
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
119 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
