Question about MSI KT4 Ultra (MS-6590-010) Motherboard
CPU Fan Hi, I have a MSI Socket 7 VIA KT400 ATX DDR ( KT4 Ultra) MS-6590 VER:1.0 Motherboard. The fan is making a noise and I would like to purchaser a new one. Can you give me a part number and place to buy one.
    President:
  • 173 Answers
Hello rc53_61,
If you look at the back of your old power supply you should be able to find the information you need (if you are going to replace the current power supply with the same one). The best place to find an exact power supply is visiting the manufacturer of your computer system for example: dell, hp, compaq, etc. You can replace a power supply rather easily, the only things you need to make sure is that the plug connection is compatible with the one on your motherboard and the power supply rating is the same or even a bit higher for wattage. Check the following links to find some good quality power supplies at a reasonable rate. These sites will help you with compatibility also by putting in your motherboard information. Let me know if you need further assistance.
Tiger direct
Directron
Just in case the links do not work properly
http://www.tigerdirect.com
http://www.directron.com
If you do not mind, please rate my help I would greatly appreciate it. Thanks
Posted on Sep 06, 2008
I need MSI-MS 6590 motherboard software for upgrade
Drivers for MSI motherboards can be downloaded from the MSI website.
Start here:
http://www.msi.com/service/download/
Aug 10, 2011 | MSI Microstar KT6 Delta (MS-6590)...
I need all the driver for a msi kt4 ultra ms 6590 mb its a amd
Browse following link
http://www.msi.com/product/mb/KT4%20Ultra.html#/?div=BIOS
Click on Download section & find appropriate drivers...
Please rate & vote this , if like solution..
Thanks
San
Mar 15, 2011 | MSI KT4 Ultra (MS-6590-010) Motherboard
Just installed msi kt4 ultra/ ms-6590 v1.0 board. can't figure out where to connect hdd led, power led, reset and power leads
Please find the info your looking for by clicking this link. you may need to register in forums 1st to read thread. Look in 'Technical' under ' General Technical Issues' for your layout.
http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=86
Aug 21, 2010 | MSI KT4 Ultra (MS-6590-010) Motherboard
No bios on kt4 ultra
You will need to contact MSI for a replacement updated bios; http://us.msi.com/index.php?func=service
Mike
Jun 07, 2010 | MSI KT4 Ultra (MS-6590-010) Motherboard
Hola tengo un drama la placa madre estaba con un disco duro zata y lo quiero cambiar por un ide pero no me deja botear como lo programo hay alguna manera de poder hacerlo placa madre:amd sempron msi k8mm3...
Placa base MSI K8MM3-V (MS-7181) de VIA K8M800 int. DDR AGP8x VGA SATA RAID LAN ATX granel sc754
Ampliar Ver producto en alta resolución K8MM3 MSI-V (MS-7181) int K8M800 VIA. DDR AGP8x VGA SATA RAID LAN ATX sc754 granel.
Producto terminado. Por favor, seleccione los artículos similares en la misma categoría
Ver más productos de MSI.
Código: AA827c
Marca: MSI
N º de producto: 601-7181-020
Enlaces: El sitio del fabricante
Enviar a un amigo
Imprimir
Perro guardián
Añadir a Favoritos
Servicio de Ayuda
Refiera a un amigo
Placa base, placa base, placa madre, placa base, placa madre MSI
Le recomendamos que adquiera junto con las mercancías
Cable de datos al disco duro Ultra cable de datos al disco duro Ultra ATA/66/100/133 ATA/66/100/133 ... 32, -
HUB de alimentación de 1 x 5,25 de energía HUB de 1x 5,25 "... 42, -
Poder adaptadores de alimentación para SATA para la Reducción de disco SATA ... 34, -
Contribuir a la discusión sólo se permite a los clientes
que ya han comprado a nosotros.
Las respuestas a las preguntas más frecuentes aquí.
Descripción de la mercancía K8MM3 MSI-V (MS-7181) int K8M800 VIA. DDR AGP8x VGA SATA RAID LAN ATX granel sc754
Calidad Placa base Micro ATX formato a un precio razonable basada en el chipset K8M800 de VIA, que pueda ser equipado con lo último Athlon de 64 bits y los procesadores Sempron con socket 754a Placa base tiene dos ranuras de memoria capaz de transportar hasta 2 GB de RAM DDR tipo 400 / 333 / 266 184-pines. Por supuesto que hay dos canales con interfaz Ultra ATA 133 y dos puertos Serial ATA, un total de hasta seis dispositivos simultáneamente. S3 Graphics UniChrome integrada de gráficos con 8 a 64 MB de memoria compartida proporciona suficiente energía para aplicaciones de oficina y el hogar. Otra extensión permite una ranura AGP 8x para una tarjeta gráfica y tres PCI versión 2.3. Disco también contiene una integrada 10 / 100 Mbps tarjeta de red Ethernet, una de seis canales AC'97 tarjeta de audio, un paralelo y un puerto serie, ocho puertos USB.
Parámetros y especificaciones:
Procesador:
Socket 754 Athlon 64 / Sempron
Chipset:
De VIA K8M800
VT8237R
Memoria:
2 tomas de corriente de hasta 2 GB DDR
Apoyo a 266/333/400 MHz
Las ranuras de expansión:
1 x AGP 8x
3 x PCI
Controlador de disco:
2 x Ultra ATA 133 (máximo 4 dispositivos)
2 x Serial ATA 150 (hasta 2 dispositivos)
Tarjeta de vídeo:
S3 Graphics UniChrome 8 a 64 MB de memoria compartida
Tarjeta de sonido:
Seis canales de VIA VT1617A, 5,1
Cumple con las especificaciones AC97 v2.3
Tarjeta de red:
VíA VT6103L 10/100 PHY
Entradas y salidas:
1 x puerto paralelo
1 x Puerto serie
1 x VGA
PS 2 x / 2
1 x audio I / O (Line-in/Line-out/MIC)
4 x USB 2.0
1 x RJ-45
conectores de expansión:
4 x USB 2.0
1 x Puerto serie
1 x S / PDIF-outNapájení:
1 x 20-pines ATX
1 x 4-pin ATX 12V
Dimensiones:
244 x 215 mm Micro ATX
Mar 05, 2010 | MSI K8MM3-V Motherboard
I have a MSI KT4 Ultra Motherboard 6590 and after
Hi! It's not uncommon for a new installation of Windows to render a PC mute. It's happened to me on several occassions, but do not dispair.
After one round or two of Windows Updates, your device will be detected as missing its drivers and they will be downloaded and installed for you.
This happens with generic motherboards which use less known built-in devices such as the sound card, the video card, etc. Should your motherboard be an Intel, Asus, or other popular name brand, you run less of a chance to get this problem.
Please run Windows Update a couple of times, or until you're satisfied your machine is up to date.
Aug 17, 2009 | MSI KT4 Ultra (MS-6590-010) Motherboard
New processor and memory - how to configure SETUP???
you need to update (flash) your bios to recognize the new cpu. check with your motherboard's manufacturer for a bios update.
May 13, 2008 | MSI KT4 Ultra-SR Socket...
MSI MS-6590 Hard Disk
Up to 160 GB is supported by the KT4 Ultra (MS-6590)
Aug 01, 2007 | MSI Microstar KT6 Delta (MS-6590)...
MSI KT4 Ultra (MS-6590-010) Motherboard Logo
153 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
