Question about TriPro Power (POW-1000AS) UPS System
Ups in problem
I have 625va ups In this offline ups when i operate in battery mode it gives reverse current in power led .mean it gives current back to main board please help me.
    Scholar:
  • 64 Answers
Your inverter shorted. Get another one.
Posted on Sep 08, 2009
My apc back ups es 650 has a continous chirp what doe that mean?
the chirp means a power event has occurred and the unit needs reset to continue operation , power events can be a few things ( to large a current was applied as a load to it , the power stayed off till battery failed and it had to charge it back up when power comes back on )
Apr 29, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
UPS disconnect (cannot retrieve information from the UPS)
use the installation cd supplied with the ups to install drivers for connectivity
Jan 23, 2014 | CyberPower 625VA Green Battery Back-Up w/...
Key disabled message
The Down Arrow and the View buttons are disabled on the T6050 as default because reverse paper feeding is not recommended on the T6050 printer because they only have one pair of tractors which are mounted above the platen. If the printer tries to reverse feed paper, it could cause a paper jam unless the platen gap is open sufficiently to allow the paper to feed down through the gap unhindered.
You can enable reverse paper feeding if you are sure that a paper jam will not occur. This is done as follows. Set the printer to Offline. Press the Mode key: display will show Offline Normal. Press any Arrow key until display shows Offline Oper. Press the Forms/1 key. Press any Arrow key until display shows Oper Forms. Press the CPI/2 key. Press any Arrow key until display shows Forms RevPap. Press the LPI/3 key. Press any Arrow key until display shows RevPap Enabled. Press the Enter key and reverse feeding will be set. Set the printer to Online. Once the reverse paper function has been enabled this option will need to be saved to prevent the setting being lost when the printer is powered off. To save the Menu Configuration; Put the printer OFFLINE Press the MODE button, then press the DOWN ARROW until CONFIG is displayed Press FORMS/1, then press the DOWN ARROW until PRINTER is displayed Press CPI/2, then press the DOWN ARROW until SAVE is displayed Press LPI/3, and with POWERUP shown in the display, press ENTER.
Mar 05, 2012 | Tally Line Matrix T6050 Printer
My nokia e72 still stay in offline mode .....how to change it..
offline may mean that the Sim Card was not correctly placed or a fall or shock on the phone has requested you to switch to offline mode and thus you are on that mode. This can be cured by turning off the phone and removing and putting back the Sim Card. You can also just change the settings to General if you had earlier inadvetently chosed the offline mode.
just try this one!!! first you do is to click the power switch for 1 sec. then it appears: switch off,lock key pad,general,silent,etc. you will see a offline word in the screen.... just choose general profile.... and this words will appear "phone is currently in offline mode. change profile to access network?" just choose yes.. i hope it will help your problem....
please rate :)
Dec 19, 2010 | Nokia N72 Cellular Phone
Offline mode
Take the battery out. put it back and power-up.
Phone will ask you if you want to start in offline mode.
Select 'No'
Sep 19, 2010 | Nokia 5230 Cell Phone
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
No power only plug light and battery light is on
The lights are indicators of which operation does your laptop operates.
1. Power indicator is lighten to green meaning you are in the mode of charging your power.and if the power indicator turns to orange meaning you are now using battery power or the charging is finished.
2. Reading indicator is blinking meaning your laptop is currently processing but if the Reading indicator is not blinking and made a static light then your system is in hang up or not reading the processes.
3. Wireless indicator is blinking or lighten then you are in the a wireless mode connection. Also the bluetooth and Infrared connectivity.
So please check which light indicator is lighten when you on your laptop.
Thanks
Aug 06, 2009 | Toshiba Satellite M115-S3094 Notebook
Bypass LED on the ups is on
This an excerpt from the UPS's manual:
The Bypass LED illuminates indicating that the UPS is in bypass mode. Utility power is sent directly to connected equipment during bypass mode operation. Bypass mode operation is the result of an internal UPS fault, an overload condition, or a user initiated command through an accessory. Battery operation is not available when the UPS is in bypass mode.
Jul 19, 2009 | APC Smart-UPS 1000VA UPS System
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
Belkin UPS F6C800 Problem
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Shutdown of UPS whenever there is a Power Surge. I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
I see that you are using
Generally, the issue happens if you are not using the UPS as per Manufacturer specifications or if it is overloaded frequently then UPS  shutdowns
To isolate the issue, I recommend you to check and go through below information.
If you see ON BATTERY a Yellow LED OR Flashing Yellow
LED with Audible Alarm (Beeping) then it means this condition for the On-Battery LED can indicate 1of 2 problems: They are:
1. The UPS is on battery backup and an intermittent audible alarm is on. The UPS will begin shutdown procedure.
2. Battery is low. The UPS will sta rt shut down. The buzzer sounds an audible alarm .
if you see a Solid Red on your UPS , then it means that UPS is either fault or overload.  It happens if there is a issue with UPS. The LED will be lit continuously and the unit will sound an audiable alarm for 10 seconds. Other cause could be with Battery is weak or Bad, the Battery needs to be replaced under this condition.
If you use a Flashing Red LED, then it means that battery is trying to give more power than it should. It happens then UPS is overloaded.
Let me tell you,,,,
Only data sensitive equipment such as a computer, monitor and external drive should be plugged into these outlets. Battery power is automatically
provided in case of a power outage. Power (AC or battery) is not supplied to these outlets when the UPS is switched off. (Do not plug surge protectors or power strips into the battery back up outlets).
 Most Important factor that effects the issue is that,
Caution: Never connect a laser printer or scanner to the backup outlets of UPS with other computer equipment. A laser printer or scanner draws significantly more power when in use than when idle. This may overload the UPS.
And caused the UPS to shutdown whenever there is Power Surge
To isolate the issue further, let me tell you the way where you can test the UPS if it is fine or not.
1. Charge the UPS for around 4 hours, and try below steps.
To Conduct a Self Test
Use the self-test to verify both the operation of the UPS and the condition of the battery. In normal utility power, push the On/Off/Test
button less than 2 seconds and the UPS performs a self-test function. During the self-test, the UPS operates in back-up mode.
Note! During the self-test, the UPS briefly operates on- battery backup power (the on-battery LED comes on). If the UPS passes
the self -test, it returns to on-line operation. If the UPS fails the self-test, it immediately returns to on-line operation and lights the replace battery LED. The loads are not affected. Recharge the battery overnight and perform the self- test again. If the replace battery LED is still on, the battery will need to replaced.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Oct 28, 2007 | Belkin (F6C800-UNV-PL) UPS System
TriPro Power (POW-1000AS) UPS System Logo
54 people viewed this question
Top TriPro Power Computers & Internet Experts
David Payne
David Payne
Are you a TriPro Power Computer and Internet Expert? Answer questions, earn points and help others
