Tracks get out of sinc when recording on Magix Music Studio Generation 6
  • 1 more comment
  • woodbesinger Sep 06, 2008
    You asked for more detail about my problem and what I have done to try to fix it.
    With Magix Studio Generation 6 I record in audio format track 1 of vocal and rhythm. Next I play back track 1 and record track 2 with lead guitar runs. Then I play back tracks 1 and 2 and record track 3 with bass, etc. For years this has worked well, but now the tracks do not stay in time with each other. For example, track 1 is a little ahead of track 2, track 2 is a little ahead of track 3, etc.
    I have tried uninstalling the program and reinstalling it, but that has not helped. Can you tell me what to do to solve this problem? Is there a patch or something?
    Thanks,
    woodbesinger
  • woodbesinger Sep 09, 2008
    I do recordings with Magix Studio Generation 6 in audio format. First I record on track one. Next I replay track one while recording track 2. Next I play back tracks 1 and 2 while recording track 3 and so on.
    The problem is that the tracks do not stay in time with each other. I have uninstalled the program and reinstalled it, but the problem persists.
    The program has worked well for years, but now I can't use it because of its lack of syncronization.
    Is there a patch or something I can do to keep using this program?
  • woodbesinger Sep 10, 2008
    Regarding the processing power, my computer has the following: Pentium 4 / 2.66 GHz and 2.68 Ghz / 1.99 GB of RAM. Please advise.
    Thank you ,
    Woodbesinger
  • 4,234 Answers
Knowing how the underlying code works as far as storage and retrieval goes, I'd suggest that you defragment your hard drive. One the track is out of sync, the remaining poertions of that track will stay out of sync. Think of it as two cars traveling at 50MPH. If the second car has a glitch befor attaining 50MPH, it will be behind the first. Assuming that it can not go faster than 50 MPH, it will remain the same portion behind. Since the initial portions of any recorded track contain information about that track and take a little bit of overhead to start, anything that slows down that process will appear like the track being out of sync. Once it has started, the recording portion is buffered, so no additional hiccups will be noticed or seen. Try the defrag and let us know how you make out.
Dan
Posted on Sep 09, 2008
  • ABRsvcs Sep 10, 2008
    By the way, the initialization issue to which I referred has nothing to do with processor power. The CPU overhead for this function is minimal. It is the disc access latency that is the main issue here. Please try the defrag and let us know if there is a change.
    Thanks,
    Dan
  • 4,472 Answers
"Media Files not in Sync" should you encounter delays in playing mediafiles in sync wit your digital audio you can adjust the playback byspecifying a correction factor 'FX' in the menu "Project", Midi/VideoLink...". see the description on the menu option in this manual. Delays while "DIRECT SYNC" with midi studio or midi connection, isthis more what your looking for? It is possible that you get smalldelays while playback between audio studio and "midi-studio" or "midiconnections" if " Direct synchronization" is active.These delays are a result of an inaccurate sampling rate of the soundcard, with a program like cakewalk the software gives you the option atthe time of installation and at anytime during a project to check thelatency of your audio programming, hardware etc. and it calibratesitself so you don't have this problem., anyhow next step. try to find thecorrect sample rate in musicstudio, keyword Try this can be a bear with this software. O.K. tocompensate for latencies you need to load a large midi song in"Evolution" or " Midi- Connections" The duration Ideally being 2min ormore. Make a recording of the whole song in music studio as a hard diskproject. Open the dialog box "Snap Definition" and set "Fixed bar snap'to the BPM value of the Midi song e.g. 110 ( Beats Per Minute) Set"Units of measure to "Bars ?Beats", activate the grid with the # key,look for a distinctive beat at the end of the song in the sequencer,e.g. at bar 100, beat 1, Set the cursor to this beat and zoom in musicstudio until you see the single beats, now change the sample rate inmusic studio in 1HZ. steps untill the grid matches the beat LeftToolbar) This will allow you to find the sample rate that your soundcard is really playing. Use this rate for recording and playback now!if your sound card plays now at a wrong sample rate or the driver doesnot accept the new sample rate, you can calculate the FX factor= newrate (f.e.44080)/ old rate ( f.e. 44100)=.995. then type in this factorin the sync dialog FX factor and the old rate, e.g. 44100Hz. The sameprocedure can also be useful to compensate problems with external synchronization in music studio or with Midi/Video Link.
Hope that helps, if you have a moment to accept and rate my solution accordingly I would greatly appreciate it.
Thanks,
lee
Posted on Sep 06, 2008
  • Lee A.
    Lee A. Sep 06, 2008
    Hopefully you will get through to my answer as a lot of experts will just throw a one sentence solution as a placeholder. When they have little to no help to offer or don't know enough in the first place. If you need any further assistance please let me know.
    Thanks,
    Lee
    Master:
  • 505 Answers
Plz explain this more thank you
  • How much ram do you have also how much is your cpu processor got
  • 13,433 Answers
Hey,
This may be a issue with not having enought processing power, can you tell me the specifics of your pc and lets see if you would need to upgrade for better results.
I had a similiar problem with another software on my old computer.
    Guru:
  • 1,894 Answers
Could you explain this more in detail.
what are you exactly trying to do and what is the problem.
also let us know the steps taken by you till now to correct the problem
Why is my 2nd recording track picking up the first recording track. I want to record another instrument, but the new track picks up the other tracks.
I don't know if this will help, but the Magix software I use create their own set of files. You can see these in the folders it will create for your project. I would specify another folder - create one - for each project or recording, that might solve the problem.
Jan 07, 2015 | Magix Music Maker 2014
Trying to get this working with my pc to record with magix music studio 2013
Apparently you're not asking about a bicycle even though you posted in that category. Would you care to specify just what gadget you're referring to?
May 23, 2013 | Cycling
How do i add music from my music file to one of the recording tracks
Generally audio editing applications can add new tracks by either dragging and dropping the music file directly on top of the program, or going to File -> Import.
Make sure that Magix Audio Studio is capable of importing the type of file you're looking to import (it will give a warning message if it cannot).
Mar 11, 2011 | Magix Audio Studio Full Version for PC...
Freezing magix music studio 12 deluxe with vista 64 bit
I think the problem is..... Magix is compatible with XP 64 bit but not with Vista or 7 64 bit, not much 3rd party software is.
Sep 12, 2009 | Magix Music Studio 2005 Deluxe for PC
Recording trouble
go to your playback option and make sure (live input) is checked, then try it
Mar 12, 2009 | Magix Music Studio 2005 Deluxe for PC
Magix studio 10
the problem is you are only recording on one side if you are using only one source, try using dual mics (with a audio interface with at least 2 inputs) or just record your tracks in stereo, then change the playback prefference to mono for listening purposes, then change back to stereo before mixdown
Jul 08, 2008 | Magix ENTERTAINMENT Music Studio 10 deLuxe...
I have a Magix music maker12 deluxe software and I am trying to figure out how to record my voice to go with the music i made!
I wonder if it works like 11 does.
What happens when you press the record button on the screen. It should be located below the tracks.
Jun 09, 2008 | Magix Music Maker Deluxe 2004 for PC
Multi track recording
I suggest that you should pause recording every after since it will overwrite the previous songs.that's it!!
Feb 05, 2008 | Magix ENTERTAINMENT Music Studio 10 deLuxe...
65 people viewed this question
 Grubhead
Grubhead
