Question about Emerson AV301 System
Bad Disc When I try to watch dvd's from a rental store the screen says bad disc and will not play.Sometimes it will play if you open and close the dvd tray multiple times. If I buy a new dvd at a store it will play fine.
    Novelist:
    Champion:
  • 277 Answers
If you sure that the system supports the disc's format, the disc is clean, and its the right region.. try to clean the DVD lens. DVD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Posted on Dec 20, 2005
"No Disc" error
try a few things first, the issue is that the disk decoder cannot get the information of the cd lan surface this is due to either a bad laser unit, or a very direct lens. cleaning is simple but if the disk cleaner didn't work you'll have to open the unit and wipe down the lens with alchohal esd safe, get at electronics store. sometimes their are stickt subtsances that get on cd discks and are transfered to the lens when it is reading cause the close proximity to the surface at high rpm's good luck.
Dec 21, 2009 | Zenith XBR716
DVD will not play a disc, when you close the tray, it will eject
Bad Disc.
Try a known good store bought Movie in player?
Still Bad Disc?
DVD unit in your player is bad.
Throw in garbage.
Feb 19, 2009 | RCA DRC8320 DVD Recorder/VCR
-bad disc reports
The problem with using rental discs is that they are dirty. Buy a dvd player cleaning disc and follow the instructions. These discs help to realign the laser. If this does not help try cleaning the disc with a disc cleaner. Also depending on how new the dvd is there have been a lot of discs manufactured outside of the US that have been bad. It may not be your machine but the discs. I personally went through 6 of the same movie before i gave up and rented something else that worked perfectly fine. Hope this helps you watch.
Sep 11, 2008 | Televison & Video
"No Disc"
"No Disc" also means "I can't read the Disc". The laser must be able to read the disc or you'll get that. There are several reasons:
Bad or noncompatible Disc: Some units won't play certain types of recorded discs. Try a rental or bought DVD.
Dirty laser lens: Either try a cleaning disc, or GENTLY clean the lens with a moistened Q-Tip.
Defective components like laser, spin motor, tracking motor, etc. Usually requires professional servicing.
Hope that helps...
Geno
Mar 25, 2008 | Televison & Video
Can't read disc
Possibly a bad, or more likely, a damaged disc.
It's not uncommon, especially with often abused rental copies.
Tell Blockbuster - they should give you a credit on the rental.
Jan 12, 2008 | Sony DVP-NS700P DVD Player
Bad disc ?
i need a change region and not have the code
Dec 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Aug 13, 2007 | Toshiba SD-P1400 Portable DVD Player
Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
Jun 20, 2007 | Polaroid PDM-1058 Portable DVD Player
Dvd player won't play-shows "bad disc" on screen
it did the same thing to me, it started to work again. it may be a memory issue. my koss player started to work again after it was unplugged for a while. Its something to do with the dvd disc not the player. if i find out , i will post again. good luck
Dec 25, 2006 | Koss KS4110 DVD Player
Emerson AV301 System Logo
156 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
