Question about HP Photosmart M415 Digital Camera
Unsupported card Why is a proper memory card (SD) showing up as an unsupported card?Three cards have been tried in this camera and all say unsupported card.
    President:
  • 1,114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
Photosmart M415
See page 166:
Also try formatting the card in the camera as cards that have been used in other cameras or formatted on a PC may not work correctly until formatted in the camera.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 06, 2008
HP 812 any SD card I use all say unsupported card?
Make sure you're using an SD card, 2GB or smaller. The 435 will not work with higher-capacity SDHC cards.
May 30, 2013 | SanDisk San Disk 4gb Micro Sd Hc Microsd...
How do I change coolpix s52 to change from internal memory to sd card?
Try formatting the SD memory card using the camera's Menu setting.
May 04, 2012 | Nikon COOLPIX S52 Digital Camera
32gb SD card is showing 0 bytes used space and 0 bytes free space
Try formatting the card and be sure the locking switch is in the off position.
Sep 14, 2011 | Transcend (589307) Media
I bought a 4gb memory (Sony) card. I t shows unsupported when turned on , is it compatable?
The M415 works with SD cards. Your 4GB card is actually an SDHC card and won't work with the camera. You need to use SD cards, 2GB and smaller.
Aug 25, 2011 | HP Photosmart M415 Digital Camera
My Nikon d80 shows the msg as card is locked,how ever i tried to solve the problem by sliding it to write position.Can someone can help me rite now?
Here is a diagram to show the correct position of the switch.
Diagram
Good big picture and it doesn't matter that it has Canon written on the SD card in the picture the SD card is interchangeable between the two makes.
Now one other thing that may also be the problem is that the SD card needs to be formatted to the camera. Formatting should be done on new memory cards and after you have downloaded pictures to the computer. That's format not delete, delete leaves a mess on the card Formatting cleans the card and provides proper communications between the camera and the memory card
Jan 21, 2011 | Nikon D80 Digital Camera with 18-135mm...
When I copy my files from my USB stick to my SD memory card and put the memory card into my camera to print the pictures, or if I want to review the pictures on my camera, it says "UNSUPPORTED FILE...
Once you use a computer to write to a memory card, it no longer works properly in a camera because of the different operating system. The only way for the card to work again is to format it in the camera. This erases and optimizes it for the camera.
Sep 28, 2010 | Cameras
I cant get the pictures to show from the sd memory card to show in the camera
A bit more information might be helpful. Is your problem that you cannot view the pictures on your SD memory card while the card is installed in your camera? If this is the case you might make sure the card is properly installed. Sometimes if the card is not fully engaged in the memory slot the camera will not register it. Try removing the card and reinstalling it.
Mar 19, 2008 | Computers & Internet
Memory Card
Try taking the SD card out then plug the camera into the p.c then format the internal memory.
Nov 13, 2007 | HP Photosmart M415 Digital Camera
Unsupported card
check the internal cable which contact with the memory card package, only easy push on it
Sep 02, 2007 | HP Photosmart M307 Digital Camera
HP Photosmart M415 Digital Camera Logo
469 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
