Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
White Speedylock differential Model @ 1500
When machine is fully threaded, do you you pull the threads straight back oir to the side tio begin sewibng?
Straight back
Posted on Oct 13, 2008
I have a white speedy lock serger model 7340. I completely pulled all threads out and now trying to re-thread new thread. I have tried around 15 times. It will not loop. Threads don't interlock at all
Be sure that you are threading each thread in the correct order. The manual should have those instructions.
ALWAYS RAISE the presser foot when threading the machine!!!! For most machines, the upper looper is threaded first, the lower looper second (the lower looper thread finishes by draping OVER the top of the upper looper and then pulled toward the back of the machine), then thread the needles. Give each thread an extra little tug when threading the tension disk to make sure it is seated completely.
Even if you are unable to locate a tutorial for your particular machine, most models from the same era will thread the same.
Don't be surprised if it doesn't work the first, second, or even the third try. It took me most of a day to get mine threaded correctly the first time!!! Patience!
How to Thread the White Superlock 534 Serger Serger Machine Series Ep 2
How to thread White Superlock serger
Sewing Machine Instructions White Speedylock Differential 1800
You can search YouTube for other videos.
Jan 06, 2017 | Sewing Machines
White Speedylock SL34D, manual
White Speedylock Differential Serger Manual
www.manualsonline.com/.../white/.../white-speedylock-differential-serge...
Find the user manual and the help you need for the products you own at ManualsOnline. ... White Speedylock Differential Serger Model Number : SL34D.
White Speedylock SL34D, manual - Fixya
www.fixya.com/support/t14860576-white_speedylock_sl34d_manual
Nov 2, 2012 - White Speedylock SL34D, manual - Sewing Machines ... i was able to find one at www.ifixmachines.com ... I have a 1500 with a manual. I could ...
Sewing Machine Instructions White Speedylock Differential ...
? 21:00
https://www.youtube.com/watch?v=-cvfkBvrw3o
Oct 17, 2013 - Uploaded by Michael Del Polito
Sewing Machine Instructions White Speedylock Differential 1800 ... That is video to help me to fix my wife's ...
White Sl34d Serger Manual
Nov 02, 2012 | Sewing Machines
My white speedylock 1600 is being difficult.. The top threads lay and look perfect.. but the bottom threads are loose.. What can I do about this?
This machine has differential feed (top tension is different from bottom and fabric feed rate can be different from bottom). turn the dials for tension and feed rates to adjust. Adjust bottom tension to tighten bottom threads and possibly speed up bottom feed rate. Tough to say without more info.
Good luck and please rate me.
From White Sewing web site.
"Are wavy fabrics making you seasick? Do puckers leave a sour taste in your mouth? Then you need differential feed. It eliminates distortion and wavy seams when serging knits, plus it prevents puckers and pulled seams on lightweight fabrics. Turn the dial again for instant gathers.
Nov 23, 2009 | White Sewing Speedylock 1600 Mechanical...
I am unable to get the machine to work. The thread breaks all the
When you re thread, make sure you take out your straight needle threads. completely then re thread the entire machine again. If this does not work. Thread your machine turn all tensions to 0 and pull your threads through at the needle point. slowly.
Nov 23, 2008 | White Sewing Speedylock 1600 Mechanical...
White sewing machine model 1620
yOU CAN GET COPY OF THE MANUALS FREE AT 1800-446-2333
Aug 28, 2008 | White Sewing 935 Mechanical Sewing Machine
White Speedylock 1634 upper looper foot broke, need new one.Please help.
Contact a sewing machine dealer in your area. He can probably order the parts for you.
sewman7
Jun 11, 2008 | Singer White Speedylock 1634
Keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
Apr 06, 2008 | White Sewing Speedylock 1600 Mechanical...
Treading my serger
When you thread the serger, your suppose to start threading the 3rd spool (left to right) first, then the 4th spool, then thread the 2nd spool which ends up in the second needle (left to right), There is a lever or bottom looper that the thread must go through before placing thread through the 2nd needle. Finally, the last spool to thread is the 1st spool (left to right). Follow the threading pattern and once you put the thread through the two loops that look like springs, turn the wheel at the right toward you until you can see like a lever with a ****, thread that **** from the back then put the thread through the machine to the right. Turn the knob to toward you again until the upper looper is showing, then you have the put your thread through the hole in that looper then through the first needle. You should now have 4 thread toward the back of your machine which you need to place under the presser foot and to the left side of the machine. There is also a VHS video that goes with the machine to help explain how to thread your serger. Also be sure that each spool of thread is in the tension of the upper colored tension wheels. If it is not, then your stitiches will be loose. Good luck and I hope this helps. I had to watch the video several times before I got it. If you don't have the video, try ebay for and perhaps you can obtain one. The video is Speedylock 1600, instructional video, USA Part #136000016, Perhaps you can contact White and see if they have one you could purchase.
Good Luck Serging!!!!
Feb 16, 2008 | White Sewing Speedylock 1600 Mechanical...
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
906 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
