Question about HP Office Equipment & Supplies
I have a HP Officejet 4315 All-in-One printer and I would like to know if the machine needs to be on in order to receive fax's.
    Sergeant:
  • HP Expert
  • 424 Answers
My HP OfficeJet 4315 All-in-One printer defaults on FAX mode for some reason. How do I change it to print?
To better help you I did the work for you... I copied this from the HP forum which if you google your issues most of the time you find the answer!
Copied from: http://h30434.www3.hp.com/t5/Other-printing-questions/HP-officejet-4315-all-in-one-printer/td-p/411239
There are generally two print devices set up when an all-in-one with a fax is set up - one is the fax device and the other is the printer. Make sure you have the print device set as the default printer and/or that when you want to print that the printer and not the fax is selected.
Setting the proper printer as default would depend on your operating system, but for most versions of Windows you would go to the printers folder, right click on the non-fax version of the Officejet 4315 and select "Set as default".
Jun 17, 2011 | HP Officejet 4315 All-in-One Printer
I have a HP 4315 officejet all in one and it prints fine...but when i try to fax a page it fails every time...why?
Good Day Sir, I have a solution to your problem, hope this will help you.
"HP 4315 officejet fax failed"
solution:
  • Turn off the machine by using the ON button and then unplug the power cord from the back of the machine. After a few seconds, plug the power cord back in and turn the power on.
  • Try to send or receive a test fax.
  • If you are running the test from the Fax Setup Wizard (windows) or Fax Setup Utility(Mac), Make sure the Machine is not busy completing another task, such as receiving a fax or making a copy. Check the display for a message indicating that the machine is busy.If it is busy, wait until it is finished and in the idle state.
  • Make sure you use the phone cord that came with the machine. If you do not use the supplied phone cord to connect from the telephone wall jack to the HP All-in-One, YOU MIGHT NOT BE ABLE TO SEND OR RECEIVE faxes. then after you plug run the test again.
  • If you are using a PHONE SPLITTER, this can cause faxing problems. connect the machine directly to the telephone wall jack.
run the test again to make sure it passes and the machine is ready for faxing.
Goodluck and God bless.
May 22, 2010 | HP Officejet 4315 All-in-One Printer
I can not receive faxes from the hp officejet 4315 ALL IN ONE PRINTER
Do I have to be by my Hp to press answer mode to receive a fax?
Apr 13, 2010 | HP Officejet 4315 All-in-One Printer
I can fax using my printer - donot know how to
sorry I botherd you - I did not have the phone line in corrctly
when I figured it out the fax worked fine
Oct 02, 2009 | HP Office Equipment & Supplies
HP Officejet 4315
HP Support Web page
<http://tinyurl.com/lbwcwd>
Error Code:
386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Apr 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Unable to send fax
I called HP and they had a free solution promptly.
Thanks tho
Apr 08, 2009 | HP Officejet 4315 All-in-One Printer
I cannot receive faxes, I have misplaced my owners manual of course!
Check the phone line with a regular phone.
Do you have digital phone service?
Jan 30, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Hp 4315 All-In-One
hi,
try to reset the fax memory on the menu of your printer...
Oct 23, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Error 405
this usually happen when sending fax ,if thats the case take the following steps
1. Press the setup button (upper right corner of the fax machine)
2. Keep pressing the setup button until you get to the fourth option which says "Advanced Fax Setup"
3. Press OK to select the "Advanced Fax Setup" menu
4. Then using the left or right scroll arrows (below the OK button) scroll till you get to the sixth option which says "Fax Speed"
5. Press OK to select this menu item
6. Press the right scroll arrow till you get "slow" for the fax speed.
7. Press OK to accept this selection.
Then initiate a fax as you normally would.
hope this helps if you have further problem do let me know
Sep 23, 2008 | HP Officejet 4315 All-in-One Printer
51 people viewed this question
Seeker5211
Seeker5211
