Question about Dryers
Button not working correctly
When you push the start button in the dryer starts when you let go of the button the dryer stops,is there a reset switch or does the button need replacing?
  • 550 Answers
The button is fine
the button starts a relay that controls the very high currents for the heaters and motor
the relay is dead, or has come loose from its connections
if the cables have come off reattach them
otherwise, replace,
not expensive to replace ~$29
trace the cables from the button to the relay button not working correctly - 5be4575.jpgnot all relays are transparent.
Posted on Sep 06, 2008
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Dryer will start when start button is pushed, but as soon as you stop pressing the button, the dryer stops
I would open up the control panel unplug the unit, disconnect the wires to the push-to-start-switch and use a paperclip to attach these two connecters. If everything works you know it is the switch that is bad.
Sep 18, 2010 | Kenmore 67841 Electric Dryer
Press start button and dryer will start and stop , if you press start button again nothing happens , if you unplug dryer and plug back in it will try to start again and stop
Howdy: The motor could be popping it's breaker once the start button is pushed. When unpluged the motor resets and the cycle starts over. But also the dryer thinks the element is too hot and resets the safety switch. The temp thermistor (overtemp sensor) could be clogged with lint or open circuit. Not easy to diagnost. Do you smell burnt wires or lint? Check to be sure the door is completely closed. It may think the door is open and not start. Doug
Dec 09, 2009 | Maytag Dryers
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Kenmore electric dryer stopped and wont start when button
Make sure there is 240vac then check the door switch, the start switch. Beyond the obviouse it is basic troubleshooting to work down to the failed component. Eric
Aug 08, 2009 | Kenmore 62602 Electric Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Dryer not working
the button you push is a momentary start switch.whats suppose to happen is the power passes thru the push to start switch for a moment till the motor centrifugal switch goes to the run winding.what i have found happening is a lint buildup in the motor switch area dose not allow the motor centrifugal switch to reset to the start winding when the dryer has finished the last its trying too start on the run winding and it could only do that if you helped by spinning the drum while hold the start switch.soooooo.... unplug unit .get to the motor and vacuum it out.inspect your wiring for burnt/loose connections.if all is well and vacuuming did not solve problem.your motor may have an open start winding which you could check with an ohm meter.if you need any more help you can make an request thru fixya email. God bless ,tom
Jan 22, 2009 | Hotpoint TDC32 Electric Dryer
Dryer stops
your motor switch is gone you can either change the switch or motor you could try tapping the switch sometimes it will free the contact this switch is on the motor
Dec 09, 2007 | Kenmore 659 Electric Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
131 people viewed this question
Top Dryers Experts
