Question about HP Officejet 5610 All-In-One InkJet Printer
Where can I find the piece of plastic with letters on it?
This is exactly the problem I have so I guess I need to find the piece of plastic with letters or marks you are talking about and glue it. Where is it located?
Thanks
Lior
  • liorlib Oct 15, 2008
    The problem is that when I turn on the machine it says "paper Jam" and there is no real paper jam.
    Thanks
    Lior
    Genius:
  • 1,605 Answers
What is the porblem??
Posted on Oct 10, 2008
How to i clean food debris How do I remove debris that is stuck in the from section of the crisper drawers?
I contacted Samsung regarding this exact issue. Woe is me I cleaned my drawers and now have water in addition to food stuck in them. The solution is... Nothing. Yup, was told there is nothing you can do. There is no way to clean between those two pieces of factory connected pieces of plastic. We have to live with it. Guess what my next fridge will NOT be? Yeah...
Apr 13, 2015 | Samsung Refrigerators
Tip
How to repair laptop key
If your keys fell off from your keyboard, you can easily repair it by following the installation guide below.
You should have a key cap, one large and one small plastic pieces (retainer clips).
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Take the larger plastic piece, it must have two larger sticks at either sides that are going to click onto the larger metal hooks on the keyboard.
Take the small plastic piece. It must have a small bar on one side that is going to click onto the smaller single metal hook on the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece. Make it one piece.
Put the plastic piece into the metal holes on the keyboard. Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
That's all.
Source: http://www.laptopkey.com
on Dec 01, 2009 | Computers & Internet
Hi I keep having the same problem with my land rover discovery series I, for some reason a little piece of plastic inside the door handle keeps breaking I've already replaced it once and now its broken...
I am guessing that the plastic bit is what holds the wire /rod in the hole of the lock lever It is a common connection piece in lock manufacture. If that is the case the piece that breaks is the bit that clips around the rod section(the clip fingers break off). Two fixes spring to mind is to use a piece of small wire (paper clip ) reposition the clip and tie to rod ( small zip tie may be easier) or 2 there are metal clips that do the same job( Mazda early models use these) but you could possible get them from a panel repair shop
Jun 20, 2013 | Cars & Trucks
What is a plastic coupler
a piece of plastic that couples/connects two items together, think of it as a link in a chain.-each link couples to the nextA piece of material (plastic in your case) fabricated to affix one or more materials to another. Just about every coupler is fabricated for a specific application. Audio, video, various type hardware, plumbing etc if you need one it is likely you need an exact replacement but not always.... good luck
Mar 29, 2013 | Bosch Exxcel WFO 2465 Front Load Washer
Shift gear light is out on 94 ls 400
Hello
You need to pop up the wood surround up. Be careful. You have to pry up the back side (near the cup holder and slide it back. There's two pieces of plastic that the wood slides into in the front and if you don't slide it out you'll break those (I learned that the hard way). The piece will still fit fine though even if they are broken and it won't be loose. Anyway. after that is out there the plastic piece that the ect switch is in. Pop that up, there are clips again, no slides. I believe you have to remove the switch from the plastic. No big deal just pry it out easily. Remove the plastic screw and there's your light bulb. I found my replacements at radioshack. They're not exactly the same size but they work just as well. To get at the gearshift light, just reach under the left side, find the two wires going into that area, grab the plug, twist and pull out. Don't try prying the top panel off (the one with the Letters and Numbers) it will break. That bulb is a tiny wedge bulb. Just pull it straight out and do everything in reverse to put stuff back together
Jun 25, 2012 | 1994 Lexus LS 400
Broken plastic on minn kota steering cable
Hi!
Here's a schematic:
Edge 40
My guess is you need key# 80 (part# 2232360 cable drum pulley)
Good luck in your repair!
Mike
Sep 19, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Chain tightener not working properly due to plastic part that holds the tensioner worn
It's that Horrible plastic again! DESIGNED to Fail!! I Hate it! I Hate It!!!
I'm afraid you will just have to buy a replacement piece.
I know this because, I had to do EXACTLY the same! As it wasn't covered under the warranty, which, you guessed it, had just expired:(
Replace the part, is basically the long and the short of the matter.
I hope you manage to replace it (relatively) cheaply.
& plz don't forget my thumbs up rating, thanks.
Jul 10, 2009 | Makita 33cc 14-Inch Bar 1.9 HP Gas Powered...
Can't put the playskool busy poppin' pals back together.
My boy put a little car into one of the animals, so I had to open it to have a look. mujin.jpg
Mar 28, 2009 | Playskool Busy Poppin' Pals
Directions to replace the Blackhawk watch battery.
Exact replacement battery you can find written on the original battery.
Do not mind the manufacturer or the letters, because they can vary. Just make sure you are buying the well known manufacturer battery, e.g. SONY, MAXELL, CEIKO, CITIZEN, RENATA, TOSHIBA, YAMAHA, etc.
The most important thing is to EXACT match of the numbers as they are giving the exact code of the battery.
EXAMPLE: Lets say: your battery have some letters and the number 1616. That means: your battery is 1.6 cm in diameter and 1.6 mm in height (thickness), or: 1.6cmX1.6mm, or simplified 1616.
As I said- do not mind the letters, as different manufcturers are using different letter codes (for quick in-house reference) and these letters have no use for you.
So, if you are ready to follow - open your watch caseback and take the battery out. Write down ALL the letters and numbers of that battery.
If you expierance any difficulties to open the watch - let me know.
Do not forget to rate, please.
Jan 23, 2009 | Chase-Durer Blackhawk Mach 3 Alarm...
A piece of clear label has stuck to something inside
You can go here and download the service manual for that printer. But as far telling you exactly where that "label" is . .I would guess either the drum or developer ..
Dec 22, 2008 | Brother HL 5250DN Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
