Samsung DVD-R135
Problem for Samsung DVD-R135
My dvd player Samsung DVD-R135 will not read any disc
By colemom on Sep 06, 2008
My dvd player Samsung DVD-R135 will not read any disc, is there any thing that I can do to fix this issue?
Thanks!
Prasad DVD player will not read disc
Same Problem
Mar 27, 2009
-   I have the same problem...My rubbish Samsung R-135 can play all the CD's either music or movies but since you eneter any DVD keep loading for approximately 3-4 min then pop up a message "disck can't read it" -   xenos35
Feb 02, 2009
-   i have the same problem with my dvd-r135.....reads cds fine, but cannot load any of my dvds. -   ucanfindme55
Jan 29, 2009
-   How do I hook up dvd player-   dragracingfa
Dec 26, 2008
-   same problem, dvd player won't read any disc-   flynlion
Nov 21, 2008
-   This unit has been nothing but problems since the warranty ran out...wont load any discs have gotten it cleaned sent it back had it fixed and still same problem SAMSUNG SUCKS-   mpswain
Best Solution
posted on Sep 06, 2008
Helpful)
VOTIT
Rank: Wiz  Samsung Expert
Rating: 84%, 852 votes
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Was this helpful?
Yes
No
8 people thought this was helpful
Solution #2
posted on Mar 27, 2009
Very Helpful)
wa8yye
Rank: Apprentice
Rating: 100%, 1 votes
I have a DVD-R135 with the same problem...won't read a DVD but will read an audio CD. Was repaired by Circuit City service department when less than one year old. The problem then re-surfaced about 6-8 months later. I've made small adjustments to the small trimpots located on the underside of the laser assembly (must remove tray assembly from the main chassis to access these) and got it working again with most (but not all) of my DVD's. Apparently this model has some issues!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung DVD-R135
Questions and Unsolved Problems for Samsung DVD-R135
Do you recommend Samsung DVD-R135?
Answer
Answer
I just got my samsung dvd-r135 and the parental lock is set. How do I get it undone.
Answer
I want to watch a movie but my DVD is asking me to change the regional code, in the dvd Menu I dont... (More)
Answer
i have a samsung dvd-sh853m recorder. when i try and play back a recorded program i get a messgage... (More)
Answer
I did not finalize my dvds in the Samsung R135, the player is broken and I can not finalize in my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung DVD-R135:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 764
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
