Question about Samsung AS18A6RB Air Conditioner
Split AC 1200-BTU Kenwood Model ANK12P Pearl series Power lights ON but Unit does not become on
  • Keen4C Sep 06, 2008
    split AC 1200-BTU Kenwood Model ANK12P Pearl series Power lights ON but Unit does not become ON.
    Its power LED becomes ON but buzzer does not beep as it beeps with normal power ON,and no response from remote control. When manual button is pressed for about 5 seconds, its whole two(7 segment ) LEDs become ON and then blower motor and compresser power supply relay becomes on. then the 2 (7 segment) LEDs go OFF. and timer LED becomes ON then (compressor) power LED becomes ON, then sleep LED (all one by one) and compressor starts normal blower starts normal and then after about 5 seconds the system goes OFF again.
    can anybody help me out . the control circuit has ULN2003 IC ,and 93C46 IC and a system control IC .......
2 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: split AC 1200-BTU Kenwood Model ANK12P Pearl series Power lights ON but Unit does not become ON.
HE, I Dont Know where youre getting these #'s from but the only thigs comes up under kenwood model ank 12p pearl series is "GERMAN" websites and nothing I could understand websites.
Posted on Sep 06, 2008
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
WILL A TRACE 2012 INVERTER RUN A 15000 BTU RV AIR CONDITIONER
According to specs, they will take a 44 amp AC power surge. Obviously number and type of batteries as well as battery condition , etc, plugged in, not plugged in to outside hydro, or generator all come in to play here, but a 15,000 BTU roof AC will only draw, 15-17Amps AC when compressor kicking in, ( or less on some new models) and should level out at 12 -13 amp draw after. As well, this will depend on proper wiring to and from main panel as well as AC unit, and incoming voltage, AC unit condition ( cleaned and maintained properly) etc.
Nov 06, 2011 | Xantrex Technology Trace Series Inverter /...
My 9000 Btu Kenwood Continental Series split unit shuts down compressor after every 10-15 minuits regardles of room temp. Gas pressure is OK & I have tried replacenig cooling sensor but to no use. I am...
Sounds like the compressor may be overheating. You need to check the outdoor condenser coil it may be stopped up with dirt, in turn, overheating the compressor. The condenser coil looks like a radiator and the outdoor fan blows through it, in a sense releasing the hot air from the building. If the coil is stopped up, it can not release the heat. You can wash this coil out with a hose and sprayer. Just be careful not to get the motor wet and be sure to shut off power.
Jun 24, 2011 | Kenwood Heating & Cooling
How much area can 1hp of this brand can cool
the 'rule of thumb' is 1 ton of AC for every 600 sq feet of a well insulated space (400 sq ft if not well insulated)- for example if the space to be cooled is 1200 sq ft - and is well insulated - you would require a 2 HP unit. 1200 divided by 600 = 2
if the space was not well insulated - you would require a 3 HP unit. 1200 divided by 400 = 3
note; 1 ton of air conditioning - is sometimes referred to as 1 HP or 12000 Btu. Whether you call it 1 HP or 1 Ton or 12000 Btu - they all three mean exactly the same thing.
take this example - 2 tons of air conditioning can also be referred to as 2 HP or 24000 Btu.
fyi - it doesn't matter what 'brand' - they all work off the same principle.
hope this helps
Jun 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
How can the model no. on coleman home ac, split system be used to determine specs? ex. mod. 9436G811 can be read as mfg. in 1994? and 36k btu or 3 ton for next two digits??
The mfg. date is sometimes (depends of the brand and the size of the unit) on the serial number.And the 36 in the model number means exactly what you think 36000 BTU or 3 ton.
Sep 03, 2009 | Heating & Cooling
Split AC 1200-BTU Kenwood Model ANK12P Pearl series Power lights ON but Unit does not become ON. Its power LED becomes ON but buzzer does not beep as it beeps with normal power ON,and no response from...
hi keen,
let me help you as I can,
first check your remote unit if it is transmitting a signal by looking at the front end of the remote using digital camera or cell phone camera, you should see a light coming on in the front end of the remote.
if there is none then the problem could be from your remote.
keep me posted thru the "ask me" button
tnx 4 using fixya
drcool
Sep 06, 2008 | Samsung AS18A6RB Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
186 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
