Question about Craftsman 25cc Gas Line Trimmer
Gas lines on Poulan Pro model 112
How deep do the small and larger line go into gas tankand how do you force them in? How are they connected to the carb /plastic primer bulb?
  • 1 more comment
  • egljoker Sep 14, 2008
    trying to separe gas tank and replace fuel line
  • Tom 14361 Sep 16, 2008
    how do I replace the gas lines. I have all 3 parts that fell off into the tank when I seperated the 2 parts.
  • Anonymous Sep 28, 2008
    dont know how to hook the gas lines up
I need a diagram or manual for a sears craftsman weed eater so i can put new
gas lines on it
Posted on Oct 19, 2008
Wat is the right spark plug for model HLT25CS 25cc line trimmer
same as the one in it , or that you removed .
Jan 09, 2017 | Garden
My john deere44 inch snowblower is throwing belt consistently, just started doing it
check the alignment of the pulleys
use a straight edge across the pulley flanges to ensure they are in line
Jan 08, 2017 | Garden
What is the air gap between ignition coil and fly wheel on a poulan pro pp4218 avx?
For practical application you can just use a new business card or 3x5 recipe card. You don't want to use same card too many times though because thickens of card will change with use, and exposure to liquids. I don't remember right off hand the exact specs but I do know we have used this method for years.
Jan 07, 2017 | Poulan Garden
I can start my barracuda but it won't run at more than idle
Timing problems, bad or warn cam shaft lobes, fuel pump going bad, no pressure. Worn corroded rubber gas tank lines, from the tank to the hard lines, just forward of the gas tank, under the car. Inspect for gas leaks.
May 28, 2015 | Garden
My weed eater will not run with the choke setting wide open.
You may have a pinhole or crack in the small hose that runs from the fuel tank to the carburetor. If equipped with a primer it may also have a small crack or pinhole. Either case may cause the carb to suck air instead of gasoline. Other possible reasons are a plugged muffler causing too much back pressure or a partially clogged fuel filter. (The fuel filter on many weed whackers are located inside the fuel tank at the end of the fuel line.)
Aug 28, 2014 | Garden
I have recently purchased a ford 1510 tractor with a 3 cylinder diesel. It seems to have low power and rough idle problem. Middle cylinder seems to not be firing because when i crack open fuel line to...
Hello, I'm not very familiar w/ your model but it could be a
timing problem, the fuel is not being injected at the right time
to fire. On a older J.D.such as the 820 ect. would not inject at the right time, there is a place on the injector pump that corrects it, however, I would call a ford tractor dealer, or go online to www.tractornet.com
and list your problem. There are many people on this site that can and will help you. Good luck.
Jul 11, 2014 | Garden
L E D christmas lights stay on when shut off.
No it's not. Your LED Christmas lights are okay. Your surge protector is fine too although the switch on your protector is an SPST type - it is connected to one line of your AC outlet. When turned off, the line with the switch is physically cut, but the other line is still alive. Some LED circuits and TFL lights blink even when the switch is turned off, probably because one line of the AC power is still (a)live. If this worries you, just unplug the LED lights from the protector.
Nov 23, 2013 | Garden
I purchased an Avid Screen Gazebo several years ago and misplaced the instructions. I have tried to look up the instructions on line and call the number on the tag with no success. I am trying to find...
Are these the numbers you've tried?
AvidOutdoors.com
P.O. Box 5932
Albany, NY 12205
Phone: 1-518-453-2436
Fax: 1-518-453-0053
E-mail: mail@avidoutdoors.com
Business Hours: 9:00 AM - 5:00 PM Eastern Time M-F
Jul 02, 2010 | Garden
Craftsman 25cc Gas Line Trimmer Logo
1,215 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dwain Pippen
Jim Parker
Jim Parker
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
