Question about HP PSC 1510 All-In-One InkJet Printer
Ink lvels How can I find out the ink levels in each cartridge on my HP PSC 1510 all in one series printer? I have Windows Vista now. I used to be able to do this easily on XP. Thank you.
  • 1 more comment
  • holliston Sep 06, 2008
    I could not find HP Solutions Center on my computer. I mentioned that I have new Vista and it isn't user friendly. I did an advanced search and it does not show up.
    My Properties does NOT have a Services option. I am lost.
  • Anonymous Jan 02, 2009
    I have the same issues here and there is not a services tab like they say....think we are just sol!
    President:
  • 173 Answers
Hello holliston,
You can try the following steps that should help you determine your ink levels.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining. Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
If you do not mind, please rate my help I would greatly appreciate it. Thanks
Posted on Sep 06, 2008
  •  Bobby
    Bobby Sep 07, 2008
    You can not go to the printer Icon and open any information about the printer? If you installed the printer software it should be there.
  •  Bobby
    Bobby Sep 07, 2008
    You can also check in the start menu and find your printer there as well. try right clicking and it should have properties at the bottom.
HOW DO I CHECK THE INK CARTRIDGE LEVELS HP PSC 1500
You can check it on the settings>Ink levels on the printer software
May 14, 2011 | HP PSC 1510 All-In-One InkJet Printer
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Oct 05, 2010 | Office Equipment & Supplies
How to change ink cartridge on hp psc 1510
Hi, Please check this link: http://h10032.www1.hp.com/ctg/Manual/c00366227.pdf
Refer to pages 43-48 (printed number on the page or pages 46-51 in the PDF page guide)
Hope this works for you.
Cheers, Ed
Nov 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
Turn off alignment feature
After you install new ink cartridges or attach the printer to a different computer it will go through this exercise. Make sure you also do the next step... a scan of what you printed-out; or you'll get that message every time.
Jul 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
How do i get the ink levels on my HP PSC 1510 All-in One printer?
Go to start, parameters, printers chosse the printer click right mouse button properties....usally you will everything there
Feb 28, 2009 | HP PSC 1510 All-In-One InkJet Printer
Vista compatability download for my HP PSC 1500 all-in-one series
The 1510 model is under the 1500 series. It is the same software for your printer
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Ink levels
Open the printer preferences, click on the services button, locate "Ink Levels" and voila!
Mar 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
Yes the download are the same for all the models..this is the link to download the driver for vista...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&softwareitem=mp-37852-1&os=219&product=428800&
I hope this helps
**Please rate accordingly**
Thank You
Computerrep
Jan 30, 2008 | HP PSC 1510 All-In-One InkJet Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
326 people viewed this question
Ben Johnson
