Question about Aiwa XR-MD100 Shelf System
The tape cover raising mechanism is broken.
I need help with dismantling information and spare parts please. The tape cover raising mechanism is broken. Peter melville
  • Kimi
    Kimi Oct 24, 2006
    Thank You
  • 1,476 Answers
Tritronics Inc. is my parts supplier of choice. They usually have or can get any parts I need and their prices are reasonable. www.tritronicsinc.com. They are agents for just about every manufacturer and will research parts based on model no., location of part and/or part description. It sounds like you will need a new door if it is broken. I've tried glueing these lids before with limited success. Tritronics would have the service manual also which would help with disassembly. Good luck.
Posted on Jun 23, 2006
I am looking for the "INNER" glass from the door of a LEF6EGSS.
Hello Julie;
Contact the following website for your part.
Peter
Glen Burnie, Maryland, USA Appliance Spares Appliance Parts Spare Parts Stokes Appliance Parts
Jun 04, 2015 | Ovens
Fix vcr eats tapes shuts down
Can only be general on this as there's not enough information provided. I suggest you remove the top cover and look around for broken plastic parts in the mechanism. The unit shuts down to prevent further damage when the tape is stuck. Look also at the Capstain Roller assembly to make certain the roller is not worn or damaged.
Jun 15, 2013 | Philips Televison & Video
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
Can you please tell me if it's possible to get parts for a duracraft  amd 8500e? I'm looking for a remote and vent hose set up. Your in hope. Peter.
Hi Peter.
Please contact you local Duracraft Suppliers for detailed information on after sales service. Also do not hesitate to contact the general air conditioner service shops. May service shops have spare remotes and other parts.
Hope this answers your question.
Take Care.
Mar 01, 2011 | Heating & Cooling
Cannot load tape. keeps ejecting tape when trying to load.
Remove the top cover from the VCR. If you have children in the house, look for any object lying in the mechanism. If this is clear, insert a tape slowly into the carriage & watch carefully if the cassette tape flap raises up & allows the tape to be lowered down into the mechanism, if not the flap lever at the side of the carriage may be broken. If the tape does lower into position, look to see if the tape is being pulled out by the guide arms, (normally 2 white poles) one of these may be broken. Check the half loading arm is also not obstructing the tape. If any of these parts are broken a new deck mechanism would be required.
Jul 06, 2009 | Mitsubishi HS-U530 VHS VCR
The VHS tape will not stay in the VCR - I have read the whole manual and can't seem to fix the problem. When it is put in, it immediately comes back out? Help!!
Remove the top cover & have a look at the deck mechanism. If there have been children in the house there may be an object lying inside obstructing the tape. If this is clear, watch carefully to see if the tape drops down into the deck mechanism, possibly the tape flap is not being raised or one of the guide arms on the deck maybe damaged or broken which stops the cassette from dropping into the mechanism. If the cassette drops down ok, does the tape then start to be pulled out of the cassette by the guide arms?
Jul 06, 2009 | Sharp Televison & Video
Sony Stereo Cassette Deck TC-V7 Will not play suspect drive belt stretched or broken Want exploded view before dismantle or to check if a part is available.
take the cover off and see where the belt is, it should be selfevidedt how it is replaced, a plate may have to be removed from the mechanism
Mar 30, 2009 | Audio Players & Recorders
Cassette removal from dead Canon MV650 Camcorder
I just solved my own problem by disassembling the camcorder until I had access to the little motor which operates the eject mechanism. It sits on the corner of the mechanics subassembly, close to the cassette. By applying about 3.5 Volts DC from a regulated power supply to the two motor contacts, it started to operate (test which direction it needs to go by trying both polarities) and lifted the cassette out of the play position and ejected it. Only since the tape was still wound around the drum, I had to use a thin tool to turn the cassette hub in order to tighten the tape a bit. Then the protective cover of the cassette closed and I could slide the cassette out of the slot by hand. Bingo!
Nov 13, 2008 | Canon MV650i Mini DV Digital Camcorder
Pioneer CD deck Receiver XR P250. Neither of the two tapes work. They dont go round.
Hi John
This is something I can tell you that you can sort out yourself with a little bit of mechanical aptitude and a couple of screwdrivers.
FIRST turn the power off to the unit.
If you pop the lid off the unit, you will see that the capstan drive belts to the tape decks mechanism have failed, Either turned to back muck like windscreen sealant, or just broken and dropped off. The belts (each deck has one) will need to be replaced. The part number for the belt(according to my records) is REB1272 You should still be able to get them from Pioneer spares directly in your country. Let me know where you are and I can get some better information to you.
good luck. Happy to assist you further and answer any questions you may have.
regards
robotek
Nov 06, 2008 | Audio Players & Recorders
Marantz Cassette Deck Model Sd 35 Tape door will not open
It sounds like the drive belts on the deck have broken (not allowing playing, FF or REW) and/or the tape got "eaten" meaning the tape itself has wound itself around the rollers and cannot free itself. I strongly doubt this is an electrical issue. Definately sounds mechanical.
As far as the door not opening, there's usually a hook that holds the door closed. If the unit is mostly disassembled, look near one of the sides of the door for a metal hook. It's normally spring loaded and can be moved manually. That should free the door. If your tape was eaten, it might take some gentle persuasion to unwrap it from the rollers.
Good luck.
Feb 04, 2008 | Audio Players & Recorders
Aiwa XR-MD100 Shelf System Logo
112 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
