Question about Westinghouse Refrigerators
I am trying to have my old Westinghouse Frost Free 17 refridgerator/freezer hauled away, but I need to determine first, and second to document, that it contains no freon. Know how to help? Bruce
    President:
  • 1,462 Answers
Look on rating plate.and it will state gas used. if it is R12 then that is freon. if it is R134a or R600a then neither are freon
Posted on Sep 06, 2008
I AM AFTER A MANUAL FOR MY WESTINGHOUSE 2 DOOR FROST FREE 517 LITRES REFRIDGERATOR MODEL RJ522V-R THANKS JULIE
Check the westinghouse web site. Many manufacturers publish user manuals for some products on their company websites..
Nov 13, 2015 | Westinghouse Refrigerators
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
I have a 17 cu ft. frost free freezer, Model F17WCE and I believe the tube is clogged. I thought if I found the plastic tube, I would wash it out. I saw the tube from the front of freezer, while lying on...
Usually you can access a service panel to where the fan and evaporation department is.
I don't know about a wood but I did work on an upright not long a go and took some pics.
See the drain hole below the fan on the floor there?
Thats what ya gotta clear. I use a shop vac myself but I let the freezer thaw all the way out , you could use a hair dryer to melt the ice.
Aug 13, 2011 | Woods Upright Freezer V1613RW3
Freezer is frost free yet it is icing up its a refridgerator
I would recommend that you turn either the freezer down or the fridge. This is somewhat normal, even frost free units will produce some frost, and this is mainly due to the temperature being too cold. Some minor adjustments and you will be fine.
Mar 20, 2011 | Westinghouse Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Evaporator freezing up on my ge gss25tsrd refridgerator
YOU CAN SEE HEAVY FROST ON THE REAR OF FREEZER WALL?
Jan 29, 2009 | GE Refrigerators
Westinghouse aurora frost free freezer.the freezer fan seems to be running all the time and should the compresor turn off occassionaly what should i be looking for,would it be the thermostat. thanks mark
It could be the thermostat. Before getting into that you should check a few other things. Check and make sure the condenser on the unit is clean and has free air around it. On some models the outer skin of the refrigerator or freezer acts as the surface for transferring the heat from inside to the outside air. These should be kept free of those stick um objects and the top is no storage area. On a frost free unit make sure it is frost free. Check the back wall for frost . If there is frost on the back wall the defrost system is not functioning properly. Check the temperature. Depending on what you are storing determines what temperature is necessary.
May 26, 2008 | Refrigerators
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
