Loud clunky noise during spin cycle
Hello Guru jsrock.
Lately the washer has been very bad.  It contiues to make loud noises during the spin cycle.  My wife and I have been washing the clothes on the delicate cycle to reduce the ruckus.  Any help you can provide woule be very much apprecitaed.
Thanks.
ServiceSoon
  • 1 more comment
  • ServiceSoon Sep 06, 2008
    Sorry about that.  That information was entered when I created this question but for some reason it is not being displayed.
    WhirlPool top-loading washer model LXR9445JQ0.
    It isn't a big deal that we have to use the gentle cycle.  However, I read in this months consumer report that using the gentle cycle reduces the amount of water that is extracted from the clothes during the spin cycle, which increases the dry time.  Makes sense.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Yes, but the loud noises you talk about can be attributed to several things. Is the wash tub off balance? Does it vibrate against the casing of the machine? Is this a rattle, or is this a consistent rythmic sound? I know this may sound odd to be asking these questions, but its the only way I can give you some sort of guess with out actually being there to hear it.
    If this is a grinding sound, you may have a gearcase (transmission) problem. If its a tapping sound, it could be something as simple as a loose wire or hose tapping against the cabinet. This could be the differece in a simple fix, or an expensive repair. Could you please elaborate more?
  • Jeff Rockwell
    Is this a FRONT loader, or a TOP loader? What is the make and model of the washer? All washers are not alike and can exhibit different symptoms of problems, and may require different courses of action to repair. Please provide me with as much information about the applaince so I can try to assist you.
SOURCE: Loud Noise - Spin Cycle
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Posted on Nov 14, 2006
okokok
  • 6 Answers
SOURCE: loud noise during spin cycle
Spin bearing is rusted from a water leak under the tub. Forget it, buy another brand.
Posted on Mar 05, 2007
kjmac
  • 97 Answers
SOURCE: My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 19, 2008
SOURCE: GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Posted on Mar 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
Posted on May 17, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
May 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Rattling noise during spin cycle
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
May 20, 2008 | Amana NAV2335A Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
