I have motel Magnavox EM3019 c401 TV. It came with preset channels. It has remote but I need to add or delete channel but Ii seems that that can be done with special remote control. Please advise
techman
  • 3130 Answers
SOURCE: need to find manual for remot
I tryed to look this up for you and I did find the remote on the web site but when I tryed to view the documentation on the remote a note came up and said that there was no on-line documetation for this remote, but I could contact Phililps for it at: 1-888-PHILIPS (1-888-744-5477) Good Luck
Posted on Apr 27, 2007
  • 236 Answers
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Posted on Sep 09, 2007
  • 99 Answers
SOURCE: panasonic tv channel reset
Unplug your tv for 24 hours and replug. This should set your tv back to ch 3
good luck----------------tomtaso
Posted on Nov 27, 2007
swampduck651
  • 5 Answers
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
Posted on Feb 05, 2008
osborne382
  • 306 Answers
SOURCE: hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Posted on Mar 17, 2008
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
I want to know how to change the preset channels on my remote
first use the remote to enter the menu and look for channel setup--you should be able to add or delete single channels that way.
Oct 30, 2012 | Curtis CMC13101 Combo
I have a LG 32ld333h tv it won't auto tune and doesn't have a add/delete how do i get it to program channels
You sir have a hospitality tv used only in hotels and motels proidium tv type that needs a master remote or call best buy to reset to consumer type tv from commer
Aug 25, 2012 | LG Televison & Video
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
Oct 11, 2011 | Emerson EWC1304 13 in. TV/VCR Combo
I got a free tv from a hotel, it has no remote. Can I use a universal remote to add channels to the tv? It only goes to channel 69. Also, can I plug in a dvd player? I can't find anywhere on the tv to plug...
Often these commercial TV's are just vanilla types catering for TV alone. The43 cable channel is possibly the only other alternative that is a money maker for the motel/hotel. They try and prevent people from connecting their own DVD players to their equipment so they are the ones who make the $$.
It is possible to use a Universal remote providing it is capable of being controlled by a remote.
Philips code is 0054 , you can only try!
Please rate my help++++Thanks for using FIXYA
Nov 21, 2009 | Philips Magnavox 27MS343S 27" TV
Add or delete channels on LXI tv
I have a Phillips LXI 46in TV. How do you save channels?
Jun 15, 2009 | Philips TP2784C TV
H25W35DT Zenith Tv locked
can you open set ups or main menu using your universal remote? if yes try to find presets, or auto program. if no, then you really have to secure the oiginal remote.
May 31, 2008 | JVC AV-20220 TV
Lost Remote
First you want to go press the menu button on the front of the tv. Second, choose channel set. Third, choose add/delete and manually preset each channel. You can try just adding channel 3 if you have cable. This will turn the tv back on and out of game mode...
Feb 04, 2008 | Durabrand DWT1905 TV
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
