Question about Maytag Neptune Washer
Spin cycle my washing machine will not spin,put new drain pump on,still wont spin.if i put it on spin with nothing inside it spins but if i put some wet clothes in to spin them it wont spin,any ideas I have the same problem. Changed out the struts and that did nothing. The basket drive sounds plausible. Does anyone know what Maytag calls the basket drive? Any other solutions
  • services777 Sep 06, 2008
    My Maytag Neptune Model FAV6800AWW recently started to wobble so badly when loaded it stops spinning. However, when I run the spin cycle unloaded, it completes the cycle fine.
    Maybe I'm wrong, but the last two responses seemed almost like automated responses. Can some one assist me by telling me possible causes for the excessive wobble?
  • 185 Answers
Sir ,
You have this problem because u may washed in heavy load,so the belt in the machine would be quite loss its performance, you have to change the belt, it may helps to work the washing machine.
NOTE:
Avoid washing heavy loaded items in a single cycle.
It may helps to increase the life of the washing machine.
Thank You
Posted on Sep 06, 2008
  • 958 Answers
777....
the basket drive is the one holding the drum...if it is sliding then it csn not spin with a load on...you have to check if the motor is running but the basket is not spinning fast enough or it is not spinning at all then the basket drive is slipping.
hit the ask me button if you want to clarify more...
tnx 4 using fixya.
drcool
  • francis rivero Sep 11, 2008
    hi again service 777,
    i've found some drawing which might be able for you to see more of the problem.
    part number 9 is called the spinner support. it holds the whole basket so you may want to check that part.
    then where it is connected would be tha next drawing.
    i hope i was able to help you fix this problem.
    tnx 4 using fixya,
    drcool
  • 4,472 Answers
I would definitely take a look at the motor coupling. It may be best for you to have a qualified technician look at the machine. If you need any further assistance let me know. If you have a moment to accept and rate the solution accordingly I would greatly appreciate it.
Thanks,
Lee
  • 435 Answers
If it doesn't spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • Posted on Sep 06, 2008
      President:
    • 2,712 Answers
    If your washer won't spin, check these:
    It doesn't pump or spin
    It pumps, but doesn't spin
    It spins only with the lid closed
    It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
    It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
    • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
    • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
    • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
    • 13,433 Answers
    Hey,
    About not spinning, please read this page
    http://www.repairclinic.com/0088_11_1.asp#Level1_3
    other common issues
    replacement parts also available
    http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
    Let me know if you need anything else.
    Thanks,
    Ekse
    • Maytag Master
    • 19,396 Answers
    Did you check the belt, the motor coupling and the bearing.
    If it is not cycling instead replace the control.
    • Ginko
      Ginko Sep 06, 2008
      Is it draining? is it getting stuck at some point of the cycle?
      If it is not draining there is still something wrong, or with the draining lines or with the water level switch.
    • Ginko
      Ginko Sep 06, 2008
      Hi, if the washin machine is wobbling, check first that is not just off balance, and that in not just a bad distributed load.
      If it is wobbling and the drum is not spinning regularly is the bearing at the rear of the drum or the drive pulley that must be replaced.
      Check also that strut and assembly are ok.
      Here you find an exploded view of a maytag front load style.
      If you need to call a repairman you can call the phone number listed on the owner manual.
    Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
    The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
    Jun 03, 2015 | Washing Machines
    Miele washing machine wont spin or drain
    clean your filter first then check there is nothing in the pump area
    Jan 22, 2014 | Miele Washing Machines
    Washer won't spin
    Good Day,
    Your washing machine is fully automatic?
    the washing cycle is normal?
    if yes do the same maybe it will help you.
    for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
    Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
    if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
    if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
    Nov 02, 2013 | Washing Machines
    My zanussi washing machine wont start a cycle. at first i thought it was the pump because it wouldnt spin cycle, so i put a new pump in and the spin cycle worked. i tried putting an a half load then and it...
    Hi tdld6365,
    Drain pump may be clogged. Even though you replaced the pump, the filter may still be clogged. Please follow my below tip on the fix:
    ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
    If this does not help, the drain pump may be faulty.
    Kind Regards
    JEDEMEYER1
    * If this solution helped you, please rate it
    Sep 11, 2011 | Washing Machines
    Washer wont drain. I hear some clicking then nothing. It will agitate on wash. No draining and no spinning regardless of which type of wash cycle I use.
    Problems with a washing machine not spinning or not draining are often inter related..
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkout this tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Jan 12, 2011 | Kenmore 24032\24036 Top Load Washer
    Washing machine wont drain keeps bleeping ERR2
    It will not spin with water in.
    See if you can locate a filter, and clean same.
    Jan 19, 2010 | Haier Washing Machines
    Washer wont spin or drain
    did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
    Feb 07, 2009 | Frigidaire Washing Machines
    Water wont drain from Machine or go onto spin cycle
    either the level control switch has become blocked or faulty or the drain pump has become stuck.
    disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
    Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
    Spin cycle
    Without any other info. this sounds like the basket drive is worn out. Depending on the brand, it has different names, but it all does the same thing. Its kind of like the clutch in your car. It has to slowly get to speed. Yours, without any clothes in it has no load. But when you add weight, it doesn't have enough power to turn it. Its slipping or just worn out. Just wondering, why did you change the water pump? Did the wheel on it break?
    Mar 07, 2008 | Washing Machines
    Washing Machines Logo
    134 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
