Best to start with driving, then check for spark and fuel/ fuel pressure. Let me know
There is spark and fuel/fuel pressure is fine. It will start and run fine, I can drive as far as I want but once I shut it off it is done for the day. It wont start until the following day.
Sorry I guess I should ask if they fuel and spark are still there after you shut it off? If so then I would do a compression test and check the timing
Also have you had it on a scanner yet? I know a lot of garages don't have the plugs, as you have an odb1 set up. Call around you should be able to find someone.
