Question about Uniden 5.8GHz Dual Cordless Phone
Ac adaptor was dropped on ground, and makes a BUZZING SOUND. Is it safe to still use
Buzzing ac adaptor
  • 5,568 Answers
It may not hurt anything; the transformer in the adapter has iron laminations which are normally potted with epoxy to keep them quiet as well as stabilising their magnetic characteristics. Dropping it has caused one or more laminations to come loose but it probably won't affect anything. You might feel the adapter now and then for a few days to ensure it is not running hot; warm is OK.
Posted on Sep 06, 2008
My Ac/dc adaptor for my R/C boat is making this buzzing or humming sound when i plac it in the socket, it make the sound before i attach the battery pacj for charging and after attaching the pack the
If it is charging properly I would not worry about it. Chargers are a device that ALWAYS make noises, there just often out of our range. If it is making a VERY loud noise, then I would suggest locating a replacement power supply.
Dec 31, 2013 | Computers & Internet
Buzzing noise
It could be feedback from your speakers... Make sure your power cord is grounded and if you have a sub or surround sound don't set the ac power adapter near them.
Mar 15, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
Just bought the RCA1023 and i have a buzzing sound trying to fix it i have it hooked to my tv through the HDMI cable i also have the audio cords (red and white) hooked up and i am still getting a very...
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still does it with no cables or anything external attached it
Apr 01, 2011 | RCA Audio Players & Recorders
When I play a CD I get a buzzing sound. The sound starts as soon as I hit the play button (and before the CD is actually moving.) It gets louder once the CD starts playing. The sound is coming through...
Mar 19, 2011 | Teac MC-DX20B CD Shelf System
When I plug it up it makes a loud buzzing humming sound that's unconteollable with the volume.
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversable, try that. make sure all audio cables are pluh\gged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
If it still does it with no cables attached it's an internal amp problem.
Dec 31, 2010 | JBL PB10 Subwoofer
My B&O Speakers are making a buzzing sound
You don't give us much to go on. What model? Self-powered?
What's "the aloy box"?
You have a ground loop or stray AC voltage circulating among your components. It could be dangerous to you and the equipment. Whatever you do DON"T touch anyhing grounded with your hand while touching what may be a 'hot' conductor.
Disconnect external cabling from the speakers and see if that changes anything. Then follow where it leads.
Maybe the source is in your unnamed electronics.
Try reversing the power cord(s). Maybe get one of those AC circuit phase checkers (available cheap at Dollar Stores) to see if your house wiring conforms to standards.
Apr 11, 2010 | Audio Players & Recorders
Buzzing from inside when off.
hi!if your t.v is always on stand by power mode and there is a buzzing sound the problem is in power supply section,you need to check for weak capacitors.
Sep 08, 2009 | Emerson EWF2004 20" TV
AC motor working but making a buzzing sound, is motor going bakd ot something slipped down into fan?
the ac condenser unit is fully enclosed, so no possible way for something to accidently slip into it. if making a buzzing sound very tell tall sign of failure.
Aug 09, 2009 | 1992 Geo Prizm
During vinyl play the sound will drop Numark TTUSB
sounds like the needle is worn down...try to replace the needle.....the buzzing sound often comes from open groung connections...that can come from the cartridge itself to the jacks on the back of the unit....bad ground and buzzing is normal for turntables and will also dramatically affect your sound level because the buzz or groung fault is higher than the sound being picked up by the needle.....open grounds can be checked with a meter set to continuity....to check for continuos line feed with no breaks in the lines.....if you find a broken line ...then that's your problem....it is a very simple repair....if the ground problem is in the cartridge...replace the cartridge which comes with a new needle as well...it's cheaper to buy it that way in stead of just bying a needle...if the ground fault is anywhere after the cartridge...then it's just a mater of replacing or repairing the line..again..very cheap repair....also...if the cartridge just clips on to the shell, sometimes it makes bad connections there too....that can just be cleaned with a little sand paper and it will work again....good luck
silvio
Jul 08, 2009 | Numark ttUSB Turntable
Loud Buzzing Noise
Check filtr capacitor in power unit.
Check filter capacitor on supply to audio amp ic. or Amp ic itself is defective.
Gopali
Apr 23, 2007 | JVC AV-30W475 30" TV
Uniden 5.8GHz Dual Cordless Phone Logo
77 people viewed this question
Top Uniden Lands Phones Experts
Dave Ellis
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
