There are a few things to check there. First, make sure the choke is working. Next, adjust the small screw below the choke assembly on the end of the primary throttle shaft (right side). Also make sure that the choke pull off vacuum mechanism is working to partially open the top choke plate after the engine starts. Also make sure that all vacuum lines are connected and not cracked or broken.
