Black & Decker TCM400 Coffee Maker
Problem for Black & Decker TCM400 Coffee Maker
TCM400 will not perk
By Guest on Dec 17, 2005
Best Solution
posted on Jun 22, 2006
Helpful)
hardrocko
Rank: Guru
Rating: 85%, 922 votes
Assuming you have power to the receptacle the unit has probably blown the thermal fuse. They are in line with the power to interupt the circuit if the unit gets too hot but over time they will blow out from all the heating cycles. The fuse looks like a small metal cylinder and come in various ratings. You need to replace it with the same rated fuse. They are available at most Electronic parts supply stores.
You rated this solution as "Helpful".
Solution #2
posted on Jun 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
How do we find this THERMAL FUSE? Where is it located ?
Solution #3
posted on Mar 31, 2008
Not Rated)
patjkn
Rank: Apprentice
Rating: 0%, 0 votes
HELP!.....my little 4-cup Mr.Coffee didn't function this morning! It was plugged in as usual, same amount of water poured in container, and correct amount of coffee for it to brew. I waited for half an hour.....and nothing happened.
This little pot has been working fine until today. It was purchased about 8 mos. ago.
I would appreciate knowing what is wrong.
thank you,
P. Jenkins
Was this helpful?
Yes
No
Solution #4
posted on Mar 20, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
How do you access the fuse?
Popular Solutions for Black & Decker TCM400 Coffee
Questions and Unsolved Problems for Black & Decker TCM400 Coffee
Do you recommend Black & Decker TCM400 Coffee Maker?
Answer
Answer
no es coffee maker-estoaster oven digital advantage modelo CTC8500TYI
Answer
tengo un horno digital advantage -modelo CTC8500TYI y no puedo usarlo por no tener el manual (me lo... (More)
Answer
What does the R and P on the caraf handle mean?
Answer
Water will not completely empty from reservoir and maker prematurely shuts off.
Answer
The coffee pot does not heat up either the water or the warming plate and does not pump the water... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Black & Decker TCM400 Coffee...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
