Question about Zenith XBS344 System
How can I take advantage of digital cable?
My cable company (Cox) has uses Scientific Atlanta boxes that have both a coax cable connection and RCA cable connections. Can you use the VCR IN LINE 1 connections on the Zenith XBS344 system to run the digital lines into from the cable box? The picture to my Sharp Aquos TV isn't as sharp when I run the cable directly into the back of it from the cable box, but I'd hate to lose the use of the home theatre system by by-passing it. Any suggestions? Thanks.
No digital sound comes from Digital Coax or Optical and in order to utilize a digital signal u need HDMI or Component although component wont be truly digital. Try running everything to the TV then the sound out of the TV into the sound system. If its a high def source like high def cable box then use the optical conection on the back of the aquos and plug than into your surround system. if ur system doesnt support Optical or digital coax then you need an updated surround system. If i misunderstood your question im sorry. If u live in CT though stop by Circuit city in North haven. either myself, Dave, or my associate Justin should be able to help you out. and dont worry we're not on commission or anything.
Posted on Feb 03, 2007
Scientific atlanta modem is not showing that it is connected to my linksys wireless router
Seems to be that you have cable modem from Scientific atlanta.
  1. Turn off the modem and the router.
  2. Connect the modem to router with ethernet cable on internet port
  3. and computer to router's port no 1.
  4. power up your modem and wait for 2 minutes
  5. then power up your router and wait for 2 minutes and try to go online on computer.
  6. If not , then reset your linksys router by pressing your reset button at the back of the router with help of a pen for 10 sec.
  7. then follow the steps again 1 to 5
  8. try to go online.
  9. if still not , the open up a browser on computer
  10. type 192.168.1.1 in the address bar and hit enter on the key board
  11. leave the user name blank and type admin in the password box
  12. click on subtab of mac address clone under set up tab
  13. click on enable and click on clone my pc's mac tab.
  14. then click on save settings.
  15. and follow the step 1 to 5.
May 02, 2014 | Linksys Wireless-G WRT54G Router
Front power indicator blinks, clicking/high pitch sound
  1. This how to is to repair hard drive, software and some firmware issues that can arise on specific cable DVR and DAC and DCT boxes, First instructions are for Scientific Atlanta hardware. Firstly, one should be certain that the cable box has the coax (cable antenna wire) hooked up to the CABLE IN or RF IN on the box itself and be connected to a "hot" outlet - one that you KNOW works. Test it by connecting a TV directly to outlet. If you get a weak signal, the box will too. Digital boxes require a clean SNR. Remove in-line "surge protectors" on the coax. These prevent the signal from being sent by your cable provider to your box.
  2. Scientific Atlanta DVR or High Def boxes:These need to be "booted" or reset when certain errors occur. No audio on certain channels when SAP is NOT set to ON and confounding error codes that one can't seem to get out of. Common yet confounding errors are : No Audio on DVR Playback. No Audio on Certain Various Channels (ruling out SAP which can be enabled through the box, OR the television set itself) there are easy ways to test. If some channels audio is in Spanish when they are normally in English...the obviously you will check SAP first.
  3. Disc errors. On screen error on your TV that says something like..."there are problems with your storage disc.." or upon DVR playback instead of playing your program it loops upon itself and plays nothing.
  4. two different steps to reboot box: Simultaneously press VOL+ VOL- and "INFO" buttons on box itself, not from remote. Box will then display "bOOt" and shut down totally. Do not press ANY buttons or try to power on said box. Wait for the correct time to display on the box. This process can take anytime from 40 seconds to hours, depending on how fast the cable company's servers are responding at that moment and whether or not you have enough of a cable signal to fire up the download process. If you call customer service for your provider if this does not work, most likely a truck roll will be run for a tech to come out to your residence to fix the signal issue.
  5. When the correct time display is on the Scientific Atlanta box, THEN power on box and problems should be solved. An alternate way to reboot box is to simply unplug unit from power supply and replugging it in. Simply powering it on and off with the POWER ON button will not solve anything.
  6. On a Motorola box and/or DVR, the easy VOL+ VOL- and INFO will not work to reboot. Remove AC power plug from wall socket and wait 30 seconds to a minute while box is powered ON. Plug back in to wall socket.Box will "do it's own thing" and power itself on on it's own after the cycle has been successful (30 - 60 seconds) and the box should power itself back to the ON without you doing anything. Time will not display on Motorola"General Instrument boxes unless you set it up to do so in the settings mode.
  7. Common IControl/On Demand errors:
  8. MOTOROLA BOX Error 225 : A billing lock to prevent you from ordering pay per views. If your account is past due, or if you have an order to move to a new address in the service provider's "system", this is a preventive measure to keep customers from loading up tons of expensive pay per views and skipping out. Your cable company cannot over-ride this error. If you are not in above situations, your provider can "up" the limit on the box and clear it so you can order PPV through your remote control.
  9. SCIENTIFIC ATLANTA: for above mentioned error code, your SA box will display not a code but a prompt to contact your provider by telephone. Same issue.
  10. MOTOROLA BOX ERRORS 204...203.. 207..these may be easily solved by simply reseating the coax and then rebooting box.
  11. SCIENTIFIC ATLANTA ERRORS 2207: reboot box. This is a general code meaning the box has lost contact with the server. All of your iControl /On Demand orders come through your local cable head-end's servers. If and when it gets overloaded and times out, error 2207/207 will happen. Most of the time this is temporary. Reboot box, try again in 15-20 minutes.
  12. DVR BOX not displaying/recording/playing items:
  13. Reboot. Good chance of fixing.
  14. If your TV displays "One Moment, Please. Your Channel Should Be Available Shortly..." this is a SIGNAL issue. Reseat the line running from wall to the CABLE/RF IN on the box and at the outlet at wall. If no joy, call cable operator.
Nov 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
Can I connect a Toshiba DVR620KU to a scientific atlanta explorer 4200 cable box?
Please follow guidelines given in operation manuals of both.
Aug 02, 2012 | Televison & Video
How do i connect cable to this tv
RCA Tru Flat has one of the best pictures for a digital flat screen. This exact TV is my bedroom TV in my home. As for the cable, you can run either a standard 75ohm coax cable or AV wires from the cable box to the back of the TV. Hope this helps.
Mar 09, 2011 | RCA F27678BC 27" TV
Scientific Atlanta Explorer 8300 says ''EXPLORER not AUTHORIZED
The message is so cryptic...it's right. There is no way to unblock it yourself. This is the box connecting to your cable company's servers and being told that, "no, you are not allowed to access content, disable yourself." It is referred to as "bricking" as the box is now as useful as a brick.
If the box worked previously and all-of-a-sudden this happened, then it could be that there is a typo in your account, and your cable company can correct it quickly. It could also be that your bill is past due and needs to be paid. Generally if it's a past due issue, a payment will reactivate it instantly.
If you are not paying for digital service and you bought this from eBay or got it at a flea market, then you'd need to add service and add the box to your account. The problem is your cable company might not like one box reappearing on another account--it seems stolen. They may just want the box back, and give you another that would work.
Apr 12, 2009 | Televison & Video
Cant get all componenets to work together
Okay so you need to run a fiber optic cable to back of bose system for sound on the cablebox if it's a hd cablebox. If you don't have a fiberoptic connection on cable box then you can use a digital coax audio cable and plug it from cablebox if it has it to back of bose system where the plugs are colored all black under the red and white connections. This cable is basically a yellow video rca type cable. That cable doubles as a video cable and a digital audio cable. But anyways once you plug your cablebox up digitally you need to make sure under the settings or setup menu of cablebox that you go under audio and make sure your cablebox is set to dolby digital instead of hdmi. Especially if it's a scientific atlanta time warner cable box. The bose remote should operate eveything still unless I read your question wrong and your saying it doesn't.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 09, 2008 | Bose 3 2 1 GSX System
Remote codes
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Symphonic TV & Scientific Atlanta Explorer 2000 cable box.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Dec 21, 2007 | Symphonic ST419E TV
Zenith XBS344 System Logo
176 people viewed this question
Top Zenith Audio Players & Recorders Experts
Damen Wong
Damen Wong
Gagan Telecom
Gagan Telecom
Level 1 Expert
Steve Allison
Steve Allison
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
