Question about LG LBC22518 Stainless Steel Bottom Freezer Refrigerator
Control Settings/Lights in error code
Looks like the control settings/lights are in an error code, but I do not know how to find out what the code is on my LG LBC22518ST Fridge (after owning for 17 months) The fridge side is blank. The freezer side has the numbers 6 & 7 lit up. Any help would be appreciated.
Thanks!!
5 Suggested Answers
  • 1314 Answers
SOURCE: Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Posted on Jul 22, 2008
  • 400 Answers
SOURCE: LG GR-292R freezer works/fridge does not.
It is more than likely short of refrigerant, needs to have the leak repaired and then recharge refrigerant.
Posted on Mar 05, 2009
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
SOURCE: lg electro cool fridge
hi mine was doing the same we recently movedhouse you need to turn the legs in front underneath so the fridge freezer is slanting so that when you open the door it will shut on its own now i have no water or ice build up on the bottom hope this helps.
Posted on Sep 24, 2009
SOURCE: LG LDC22720SW ECU reads 5-6-7 on freezer side
I have a similiar problem with my LG refrigerator. The freezer settings get stuck on 6 and 7, while the refrigerator side is showing nothing. Pushing the buttons to adjust the temperature does nothing. The whole time, my food is getting spoiled.
Posted on Oct 18, 2009
All the lights are lighting up at once
IC fault. Buy an other remote control This remote control is irreparable. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Apr 04, 2014 | Gefen Remote control RMT-4IR Remote...
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
My x box 360 had the red ring of death, but after a few days cleared itself, but now the wireless controllers will not sync with the unit. They both just blink green lights. i bought a usb cable to plug...
Just to make sure your doing to resync right, first press the button on the console then on the controller so the light on the console is rolling and then on the controller.
there is not much that we can do, unless you get the 3 lights back again that would help us a little to know what fault it detects. now the wireless controller board can be replaced, but since the USB is not working either that would not fix the problem.
it looks like there is something wrong with the mainboard of the xbox, and I won't know more until you get the 3 red lights again and we read the error code from the unit.
to read the error code when you have 3 red lights flashing. Hold down the consoles controller sync button and then press on the eject button, the flashing lights will change, note how many lights do you see, write it down or something, and then press the buttons again, now again the lights change, note how many and do it 2 more times, and you should be back to the 3 lights, tell me what error code it gave you.
now a example of a error code = 4 lights, 4 lights, 2 lights, 4 lights. That would be 0020
(4lights = 0, 3 lights = 3, 2 lights = 2, 1 light = 1)
Feb 28, 2011 | Microsoft Xbox 360 Controller
Have f1 code at times and lights around knob of settings flickers
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My scanner wont work
Make sure the Lexmark is the default printer in printer settings ( in control panel )
If that doesn't help please give some more information about any error codes or flashing lights that appear.
Good luck
Sep 10, 2010 | Lexmark X6150 All-In-One InkJet Printer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Replaced bank 1 sensor 1 O2 sensor with an OE
Those lights indicate an issue with ABS or traction control systems. In order to properly diagnose the problem the vehicle's codes will need to be read with a scanner.
Generally speaking there is no danger in driving the vehicle but be aware you may not have functioning traction control and/or ABS while those lights are present.
Feb 01, 2010 | 2003 Lexus Gs 300
Xante Ilumina 512 error code
this error can be caused by a new or existing PC on your network. EXAMPLE: the network settings on new DELL pc's are default set to control the network and repair any conflicts..it seems dells dont like Ilumina's, and they get this error code.
Disable the network control function in the DELL settings.
And this error will not re appear until another dell is installed.
Jun 04, 2008 | Xante Ilumina Digital Color Press Printer
LG LBC22518 Stainless Steel Bottom Freezer Refrigerator Logo
19 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
