Question about Mackie SRM-450 System
Mackie srm-450 constant annoying hum (buzzing) even with no input plugged in
I've tried ground lifting, but it did'nt help. Is this normal for these speakers? All of mine do it. I used to have a very quiet, clean key rig. Is this why they came out with V2? Are they quiet? Is there a mod that can be done to these to resolve this? Thanks in advance for any help!
  • 4 more comments
  • Anonymous Nov 10, 2008
    i have the 450 v2's and i have the same problem. i think it might be the actual wiring of my house...
  • robbed999 Dec 18, 2008
    yep - annoying excessive hum/his.
    spoils good aspects of equipment
    Robert
  • melroe Feb 09, 2009
    I have the same problem but it seems the problem only occurs when the mackies have warmed up for about 10 minutes. It seems they have a internal switch that turns on when sound is put through them and shut off when there's no sound and it seems it's only coming through the horns. I think mackie needs to address this problem?
  • theedj Mar 06, 2009
    I bought six of the  mackie srm 450 powered mackies. I've sent 1 back due to pre-mature overheating at low input levels. In 1 of the others the high freq went out during a speech. One of the others won't power up at all. And they all hum no matter what source of power they're receiving. I was told by Mackie engineer that they had a bad batch. Maybe you have the same series batch as I do. Too much many to spend on all these problems.........
  • melroe Mar 30, 2009
    I would like to know from Mackie what serial #'s they made the bad batch from so I can check my #'s
  • infimious Apr 23, 2009
    I have My computer hooked into my Reciever (Green plugs at the tips) for audio...then i have that connected into my pioneer CS-907 Speakers...I have a constant buzzing sound....Please help...Thanks!
    New Friend:
  • 59 Answers
Mix, try this...Get everything in your audio system together.get a coupla power strips. Power up both speakers on that strip with no inputs, just the speakers. gotta hum(60hz)? ground-lift the strip and see if it stops. add one peice of the puzzle at a time until you find your buzz generator, if you're a mobile DJ, doing gigs in 'God Knows Where' you would be well advised to buy a "Power Conditioner" that will level out spikes and dips in the voltage servicing your gear.
Posted on Dec 05, 2008
My Mackie SRM-450's both make excessive white noise, one of them crackles quite loudly.
This type of active speaker by Mackie has a issue with operational amplifier ic's inside, they are just those little black things with 8-pin soldered to the pcb, you may have some of them damaged, because of the erratic operation of the units, let me know if i can help more.
Jul 04, 2013 | Mackie SRM-450 System
My srm 450 dont automatically turn off when its not being used. Yesterday that same one started to smell burned and smoke coming out of it even though nothing was being played
Generally speaking this is a common issue with SRM-450 and it's due to opamp burned out inside electronic pcb, let me know further to improve help.
May 01, 2012 | Mackie SRM-450 System
Where can i buy parts for my mackie srm 450 powered speakers
This speaker has a very commercial not-hard-to-find electronics, so you can try Mouser, newark electronics, D'Albani corporation, even Radio Shack, hope this helps.
Sep 27, 2011 | Mackie SRM-450 System
The tweeter of my mackie srm 450 V2 makes a quite loud noise (humm). this nois was there right from the beginning, and mackie told me, that this was usual....the older 450´s did not make this kind of...
The latest 450v2 include this metal portion 1 to isolate AC lines over IC's, metal part 2 is include in all versions, some technician remove them and that creates more hum at idle levels, by having both the latest 450v2's are the quietest of the v2's.
V1 did not use switching power supply, they use discrete circuit and that is why they are a bit quieter
Aug 04, 2010 | Mackie SRM-450 System
I have 2 SRM-450v2's. How do I hook it up to my 1604 VL2-Pro Mackie mixer?
You should see a left and right main output on the 1604. Connect these to the line inputs on the SRM450s. Set the input volume control about mid way on the SRMs to start. Vary the volume control as needed to give you the most flexibility and control from the mixer.
Dan
Jul 03, 2010 | Mackie SRM-450 System
Humming speakers
If you disconnect the signal leads and the hum is away, it's probably a groundloop problem, or your equipment is generating the hum.
If it does not go away, the amps are defective
Sep 23, 2009 | Mackie SRM-450 System
Humming problem
This could be a grounding problem, it might change if you plug it in elsewhere or it might be where you live.
Jan 28, 2009 | Mackie SRM-450 System
Mackie SRM-450 System Logo
1,904 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
