Question about PC Chips M870 Motherboard
M870 motherboard i have 2 usb ports in the front of my computer and 1 mic and 1 headphone sockets but i dont know were they go on the mother board please help
    President:
  • 1,257 Answers
Check the motherboard setup manual..
Posted on Sep 06, 2008
Motherboard specification
Intel 865GV Chipset Pentium 4 Main board,
Supports Prescott CPU
FSB800, DDR 400, SATA 150 Specifications
arrow_bullet.gif CPU
  • Supports Intel Pentium 4 Socket 478 processors(Prescott and Northwood) with 800/533/400MHz FSB
  • Supports Intel Hyper-Threading Technology
arrow_bullet.gif Chipset
  • Intel 865GV/ ICH5
  • Integrated Intel Extreme Graphics 2
  • Supports Advanced Configuration and Power Management Interface (ACPI)
arrow_bullet.gif Memory
  • Two 184-pin DIMM sockets
  • Supports 2 DIMM Single/ Dual Channel DDR 400/ 333/ 266 memory (Max. 2GB)
arrow_bullet.gif Graphics
arrow_bullet.gif SATA 150
  • 2 channel Serial ATA 150MB/s data transfer rate
arrow_bullet.gif Audio
  • 6-Channel AC 97 CODEC on board
  • Professional digital audio interface supports optical S/PDIF Output
arrow_bullet.gif System BIOS
  • Supports Plug-and-Play (PNP)
  • Supports Advanced Configuration Power Interface (ACPI)
  • Supports Desktop Management Interface (DMI)
  • Write-Protect Anti-Virus function by AWARD BIOS
arrow_bullet.gif LAN
  • On board 10/100Mb LAN
arrow_bullet.gif Internal I/O Connectors
  • 3 x PCI slots
  • 1 x Floppy Port supports up to 2.88MB
  • 2 x Ultra DMA 33/66/100 Connectors
  • 2 x Serial ATA 150 Connectors
  • 2 x USB 2.0 headers (Each header support two USB 2.0 devices)
  • 1 x CD-IN, 1 x AUX-IN
  • 1 x FP-Audio header
arrow_bullet.gif Back Panel I/O
  • 1 x PS/2 Keyboard, 1 x PS/2 mouse
  • 1 x Parallel Port, 1 x Serial port
  • 1 x VGA Port
  • 1 x Audio connectors (S/PDIF Out, Surround Out, Center/Sub, Lin-out, Line-in, Mic)
  • 4 x USB 2.0, 1 x RJ-45 LAN Connector
arrow_bullet.gif Miscellaneous
  • Micro ATX form factor (244mm*234mm)
  • Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
    hope this helps
Jul 07, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Case wire two mother board
Here is your front Audio guide:
http://www.fixya.com/uploads/images/3C3CD07.jpg
Here is your USB guide:
http://www.marnscda.com/Guide/USBPinMB.jpg
And here is your front Panel guide:
http://www.elhvb.com/mboards/intel/pinout-OEM-Intel-2x9pin.jpg
Let me know how that works out. The front panel guide is rotated 180 degrees however.
May 02, 2009 | Foxconn 661FX7MF-S Motherboard
CAN'T IDENTIFY MY MOTHER BOARD
Download CPUZ from this link. This app will give your mobo info.
Apr 02, 2009 | Computers & Internet
Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Apr 01, 2009 | Dell Dimension 4600 PC Desktop
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
No sound from front headphones
check your speaker is good and it i inerted in the correct slot and it raise the error of POST so the mother board power had some problem cheak wether the led in the mother board glows properly once it correct check with your board input power +-5,using your multimeter.or else there is a problem in your smps
Mar 25, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
Back Panel Connectors
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
Mic port not working
1. Check the Audio I/O settings in Realtek Audio Manager in system Tray Icon on Taskbar,
2. Try to connect your Mic to Front pannel of system Unit.
or Reinstall audio Drivers.
Feb 22, 2008 | Intel D101GGC Motherboard
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Jun 01, 2007 | Intel Motherboard
PC Chips M870 Motherboard Logo
224 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
