Question about RCA RS2505 CD Shelf System
Cd player every time i put in a cd, it says "reading" for about 5 seconds, then it reads "no disc".. and it doesn't spin the cd at all. i've tried every combination of using different CDs, or having it open and then pressing the button of the cd that i wanted it to go to. but it always does the same thing. if i have all 5 cd trays filled it just skips through each one until it has read all of them and tells itself that there is "no disc".
  • 1 more comment
  • Anonymous Feb 26, 2009
    I have the exact same problem.
  • Anonymous Mar 20, 2014
    the cd player does not acknowledge discs. it opens clicks through each disc and after going through all 5 discs says no disc
  • Anonymous Mar 25, 2014
    Disc tray won't open or function when button is pressed
    Novelist:
    Champion:
  • 277 Answers
RCA has had lots of bad laser pickups the past several years. It has to focus before it will spin. Sometimes they will focus and spin but still not read the disc. Unfortunatly that unit is a throw away and no parts or service literature is available from RCA/Thomson. So if cleaning it does not do it, you are probably out of luck. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Posted on Dec 18, 2005
CD player rotates but wont play or read disc.
Cd spins but player can not play - ecoustics.com
www.ecoustics.com > Forum > Home Audio Forum > Mini Systems Forum
Oct 30, 2003 - Cd spins once system is on but player can not read discs. ... Traywon't eject. ... I have a Memorex 2Extreme CD player, and I insert the disk, and pushplay, and the CD acts like it's searching for awhile and then the screen ... Dvd player won't read any CDs (but use to ) - eCoustics.com
Sep 22, 2005
Cd makes clicking noise and I get Disc Read Error PLZ HELP ...
Dec 24, 2004
CD Player screen reads no disc - ecoustics.com
May 30, 2004
More results from www.ecoustics.com
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
How to fix a boombox CD player when it wont play .... My box reads "no disc", but it is in proper position ...
Dec 22, 2015 | Audio Players & Recorders
Cd will spin for about 5 seconds and stop
The drive has failed. It can't read the disc.
Nov 20, 2014 | Audio Players & Recorders
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
Sony cmt-ne5 cd reads no disc
Then it is time to replace this player the Laser reader is defective or the disk doesn't spin due to a defective drive motor, in most cases they don't even sell parts for these players and they are not repaired unless under warranty.
Jan 23, 2012 | Audio Players & Recorders
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Player will not read cd . Cd will not spin
Without me seeing it, it usually cannot read the disc and is caused by a defective, or needs to be adjusted or cleaned, laser assembly as long as it is every cd put in it. It can also be the disc spinner motor. Either one of those is the most likely cause. :)
May 19, 2010 | Yamaha CDC-845 5-Disc CD Changer
MY Macbook pro disc drive wont read the Starcraft game discs. Every other cd or dvd i put in the drive at least reads, but when I put in starcraft it just spins for a second, pauses, and spins again...
I was pretty disappointed when I couldn't play a 12 year old game on my new macbook either. The best thing to do is go to battle.net, load up the CD key and then load the software onto your mac. The downside is that you will need internet access before playing even if you play single player. That's the way I got around it.
Apr 11, 2010 | Blizzard Entertainment StarCraft Battle...
Stopped reading cd's
its means that your CD player cannot read data. actually the problem is in your lens. try to clean frist by cd cleaner disc with liguid and try. same problem change CD OPTICAL LENS.
Jun 07, 2009 | Audio Players & Recorders
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
B&o sound system not working
try buying an ordinary cd lense cleaning (CD), if you are brave you can try adjustind the pick up of the laser on the laser board pot inside the cd player. it might just need a service
Nov 27, 2007 | Bang and Olufsen Beosound 2000 Shelf...
RCA RS2505 CD Shelf System Logo
332 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
