Question about Texas Instruments TI-83 Plus Calculator
Conversion I have the TI-83 Plus. Can i convert the english units to metric and vice versa, does it allow for the conversion of weight also like pounds to kilos and aslo feet to meters and volume like cibic feet
  • 1 more comment
  • theexporter Sep 08, 2008
    Im still lost. a manual, cant find it, a application that would calculate and convert square feet to meters and lbs to kilos
  • Anonymous Mar 15, 2014
    would like to convert 81 kilos to pounds
  • Anonymous Mar 29, 2014
    2.25kilos to pounds
  • 32 Answers
Heres one called science tools and it has sig figs, vectors and unit conversions and one other. http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&tabId=1&appId=205
Posted on Sep 13, 2008
    Brigadier General:
  • 5,158 Answers
Conversion PSI to NM
The conversion is from inch pounds to Newton Meters
The factor: 1 Lb-Ft = 1.35582 Nm.
The direct quote: boltscience.com
Torque is a measure of how much twisting is applied to a fastener. The units used to measure torque are in the form of force times length.
The metric (SI) unit of torque is the newton metre (Nm). In inch units, torque is usually measured as Lb-Ft (pounds feet) or Lb-In (pounds inch). The Torque Converter Calculator will allow you to convert Nm to Lb-Ft or Lb-In or vice-versa. The calculator uses the conversion 1 Lb-Ft = 1.35582 Nm.
HOPE THIS helped
Torque Units Conversion Online Units Converter
Oct 25, 2016 | Cars & Trucks
My digiweigh scale reads 0 - LD what's that mean
Hi Douglas 0-LD means your digiweigh scales are in pounds, 0 means no weight and LD means pounds..... The link below shows how to convert LD to KGS (pounds to kilos)
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Mar 26, 2016 | DigiWeigh Measuring Tools & Sensors
Cannot get it to simply read weight in pounds
Hi dave,
Here is the Simple example of converting weight to pounds.
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Hope it helps.
Thank you for using fixya.
Sep 09, 2011 | Health & Beauty
I have staples BD-6350M Metric Conversion caluctor and i am just stuck on how you use it to convert the numbers
Hi lemony fresh Oooo!!
I have a very similar cute little calculator. Don't you think that's nice?
I can't make out the print above each key, so I'm assuming:
1.- The arrow key (under M+) pointing to the right is TO METRIC
2.- The arrow key (under M-) pointing to the left is FROM METRIC
Above all the other keys youll see things like incm, ftm, lbkg and so on.
Now for this example, most people know that 1 inch = 2.54 cm
Just as an exercise, we'll convert 10 inches into ??? cm OK?
You know the answer of course, so you'll know if the key sequence was correct, right?
The key sequence is:
1. Enter the amount. In this case it is 10
2. Now press the TO METRIC key.
3. Now press the key under incm
The answer is displayed immediately! .... 25.4
Now, you get a package that weighs 1 kilo and you need to know its weight in pounds.
(pound = libra .:. lb)
You already know the answer before hand, 2.2, so let's find out if the key sequence is correct.
1. Enter the amount. In this case it is 1 ( 1 kilo )
2. Now press the FROM METRIC key.
3. Now press the key under lbkg
The answer is displayed immediately! .... 2.2045855
For practical purposes, the accepted norm is to say: 1 kilo=2.2 lbs
The little leaflet that comes with the calculator is not very helpful, so I went through the same pains initially.
I trust this has shed some light on the subject.
Jun 30, 2011 | Office Equipment & Supplies
Convert metric weight to pounds
Good luck.
Apr 22, 2011 | Office Equipment & Supplies
How to convert Metric tons to long tons
To my knowledge the TI-83 doesnt do conversions.
1 metric ton = 0.984206528 long tons, so if you just multiply that number by the number of metric tons, you will get your converted number.
Sorry there isnt a built in parameter to my knowledge. If you upgrade to the TI-85, I believe you start to get some of that functionality!
Feb 23, 2011 | Texas Instruments TI-83 Plus Calculator
I have a ti-30xa and need to convert metric t standard or other way around
Sorry, the TI-30XA does not offer unit conversion functions other than angle units. The best thing you can do is to get the conversion factor from a table in a book, or look it up in the internet, and store it into one of the three M memory places of the calculator.
Use the memory recall and divide or multiply to convert.
Example: Convert metric tons (Mg) to international avoirdupois pound (lb), and vice versa. Conversion factor is:
1 lb = 453.5937 Mg.
  • Key in 453.5937 [STO] [0] to put the conversion factor in memory 0.
  • To convert 17 Mg to lb, key in: 17 [÷] [RCL] [0] [=].
  • To convert 5 lb to Mg, key in: 5 [×] [RCL] [0] [=].
Jan 16, 2011 | Texas Instruments TI-30XA Calculator
I have a TI-83 Plus calculator and was wondering what do i have to do to be able to convert to different number bases like from decimal to hex
There're no base conversion facilities built into the TI-83 series calculator. You can download a variety of programs for this from http://www.ticalc.org
Apr 07, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 plus
Yes there is check out this link and download the program. Send it to you calc through ti connect. http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&tabId=1&appId=205
Sep 06, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
600 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
