Question about Xerox Phaser 7300DN Laser Printer
Xerox phaser 7300 toner cartridge problems
I have a xerox phaser 7300 and I just put four new toner cartridges in a week ago and the printer printed for a couple of days and then stopped because my yellow was out. Is there a reset for the cartridges, I didn't get prompted to reset when I installed. Any help would be greatly appreciated.
  • charagdeen Jan 14, 2009
    I have a simialr problem with Xerox 7300 black and cyan toners. Any help will be greatly appreciated!
  • 97 Answers
You can reset the toner cartridge count in the service menu. Full details on how to do this can be found on my website here.
Posted on Aug 08, 2012
    Scholar:
  • 49 Answers
Sometimes on this machine as there is a lot of loose toner around it can cover over the sensors in the machine, what I would advise is to remove all the toner cartridges and check for the copper contacts on both the machine and under the imagining unit (which the toner is placed in). Once you have cleaned that away slowly close the lid and reboot the machine and it should return to normal. Its just toner getting caught up in the sensors. Follow the instructions below, when you remove the unit, lift it over your head to find the copper contacts and clean them, be careful not to spill toner everywhere. Good luck!
Reseating the imaging unit
    Remove the toner cartridge:
  1. Open the top cover.
    caution_image88x30.gif The imaging units are sensitive to light. Do not expose the imaging units to light any longer than necessary to remove it and cover it. Failure to follow these instructions may damage the imaging units.
  2. Identify the color of the toner cartridge to be replaced (Cyan, Magenta, Yellow or Blaxerox phaser 7300 toner cartridge problems - identifycolor176x179.gif"http://i.fixya.net/uploads/images/identifycolor176x179.gif" alt="identifycolor176x179.gif" class="h_mi" />
  3. Move the orange lever on the xerox phaser 7300 toner cartridge problems - moveleverright204x202.gifght so that it unlocks.
  4. Set the toner cartridge on paper to avoid any toner spilling.
    Reseat the imaging unit:
  5. Lift the imaging unit straight up out of the printer.
  6. Line up the guide pins with the printer's frame and lower the imaging unit back into the printer.
    Reinstall the toner cartridge:
  7. Install the toxerox phaser 7300 toner cartridge problems - moveleverleft202x221.gif the front onto the new imaging unit first then lowering the back.
  8. Move the oranxerox phaser 7300 toner cartridge problems - closetop212x223.gifer cartridge to the left so it locks.
  9. Clean the LEDs with the supplied wipe.
  10. Close the top cover.
Posted on Mar 31, 2009
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Refilling toner in xerox phaser 6280
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your model printer.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 27, 2012 | Xerox Phaser 6280 Clr Laser Printer 26Ppm...
I have a Xerox phaser 7300 that keeps telling me to install or reseat the black cartridge
It is slightly unusual for it to be the black toner cartridge (usually cyan or magenta) but this issue is quite common on the 7300. You can find a lot of information about this here.
Dec 15, 2010 | Xerox Phaser 7300DN Laser Printer
I have a phaser 7300 that asks for a transfer unit about every 3 weeks. It prints good until it asks for unit and then it will not print until I install a new one. I am ready to install the 4th unit but...
I think you might have a Spring missing for the Waste Toner Full Sensor. The machine tolerates the sensor status for 2K pages and then shuts it down.
Truthfully, it is really hard to describe in a few sentences. It belongs in the frame wall under near where you have the white waste toner section of the Transfer Belt. This spring pushes a flag up that hits the Paper Entrance Sensor (yes, near the bypass tray)
The PN for the spring is 116-2050-00.
Whit
Item, Inc.
May 21, 2010 | Xerox Phaser 7300DN Laser Printer
I have a Xerox 7300 that I started using Media Sciences toner in. I have had to replace 3 imaging units recently because they have locked up. Now 2 are locked up again. Media Sciences says they have not...
Hi.
Xerox says instead that the user should never used non original or refurbished cartridges, as in a number of cases this had been proven capable of damaging parts like the imaging unit.
I am sorry for Media Science, but they do not even have permission given by Xerox to build compatible cartridges (Xerox Corporation Filed a Patent Violation Lawsuit Against Media ).
Cartridges that have not built and tested with full printer manufacturer cooperation cannot be free of problems.
Also, I know that the 7300 is probably out of warranty, but using this cartridges on a new printer may invalidate the warranty.
Media Science does not make itself responsible in case one of their cartridge has damaged a printer.
My suggestion is to use original cartridges in future.
Best regards.
Ginko.
Feb 22, 2010 | Xerox Phaser 7300DN Laser Printer
The "Reseat Toner Cartridge" message keeps appearing, if I open and close the lid the message goes away and it seems to print normally.
There is a firmware issue that causes that problem.
You can download it from the Xerox.com site and upgrade your machine. The instructions on doing that upgrade are also on the site.
Go to Xerox.com. Then click Suport and Drivers, then enter 7300, then to drivers and downloads and scroll down to the firmware update.
Feb 10, 2010 | Xerox Phaser 7300DN Laser Printer
We have two printers and both of them have the following error command when we print. Reseat or Install Magenta Cartridge. This command is repeated on other colours at random
Issue could be caused by a couple of things. Could be the Toner Sensor Actuator's, located in the top cover. Could be the toner Sensor Board, also located in the top cover. Could be the Engine Controller Board.
Any one of these three can cause this issue. You can watch my tutorial video on how to replace the Toner Sensor Actuator's on YouTube. It's about 10 minutes long. Just search for Xerox 7300.
Nov 03, 2009 | Xerox Phaser 7300DN Laser Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Xerox Phaser 4510 laser Printing Quality
Hy, this problem is caused because the print cartridge is out of range. try changing with other cartridge from the other machinne. or buy another cartridge
Jul 17, 2009 | Xerox Phaser 4500 Printer
Xerox Phaser 7300DN Laser Printer Logo
1,329 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
