Question about Rio Carbon MP3 Player
Volume Control The volume control is depressed inside the cavity of the body and will no longer function. How do I get it fixed.
Well there is something I can do for you. If you are in warranty, send it back but if not, don't be afraid to tackle it yourself. The volume wheel seems to be the rio's main weak spot. Mine broke twice and i have been able to repair it both times.
you need:
1 tube 2-part epoxy glue
1 sponge
1 bottle methylated spirits
1 sewing needle
some pieces of paper or other disposable surfaces
The following link shows photographs of someone else opening their rio (hard enough to do at first) with useful instructions in the captions.
http://www.splitbrain.org/blog/2006-07/28-carbon_repair
I advise opening the device with rigid plastic implements instead of screwdrivers to prevent damage to the exterior or the player and the components inside. Don't be afraid of using a bit of force in taking of the back casing. Once you have a tool inserted through the bottom of the device, (no innuendo intended here :-) ) you can lever the back cover off.
First clean the surfaces to be glued with the sponge soaked in a small amount of methylated spirits and let each dry.
I used 2-part epoxy glue available in a hardware shop. I mixed a blob of this on a piece of laminated paper and applied some of it to the two fracture points on the wheel with the eye of a large sewing needle.
I did a few practice runs with pieces of paper before i went for the real thing. You have to be careful because the two points to be re-attached on the player are very small and are very close to moving parts.
Once the glue is on and you are happy with its neatness, place the wheel back on the player as best you can so that the fractured points match up once again. marking the back of the wheel may make this easier. Then hold the wheel and player tightly together with your hand with your thumb on the wheel for 15 minutes. You can rotate the wheel to ensure that the glue has not adhered to moving parts. Be patient and keep the bond still. You may have to reapply the glue if after the 15 minutes if the two surfaces have not been adequately bonded. Remove the glue from both wheel and player with Methylated spirits and the sponge and start again.
Once the glue has been let harden for 15 mins and you are happy with it (test it gently by slowly rotating the wheel while the carbon is on if you like), leave the rio in a safe place for 24 hours after which you can re-attach the back cover and once again enjoy your music!!
Posted on Aug 11, 2008
    President:
  • 3,130 Answers
This is a problem with alot of small electronics these days. If and only if you feel comfort with taking this unit apart will it help correct the problem your having.. My recomindation would be to send back to the manufacturer because Im sure this is not the first case history they are having with this model as there are really no serviceable parts for the consumer as well a good service tech. These are all surface mounted switches and buttons that do break off at the cabinet level. Not alot you can do sorry man.
Posted on Mar 27, 2006
What are the main cause of a choppy sound when you try to adjust volume
Dust accumulation on the inside of the volume control. With the amp off rapidly change the control from stop to stop several times or until the sound is no longer choppy. If this doesn't work then the volume control will need to be replaced. This trick works for a car radio too.
Jun 20, 2015 | Audio Players & Recorders
Volume / audio control knob
Hi, did you ever get this fixed, if so for how much and where. I have the same problem with my knob, it does not control the volume level but you can still access the other functions that require you to push the knob, like a button. My remote battery is dead so I have not being able to test it, it's just the knob no longer controls the volume.
Dec 01, 2011 | Audiovox MP6312I
The volume control will no longer increase volume
this is common, It may well work for most functions then let you down an one like volume! You should have at least three (but it should be more like 6) different codes to try and one should work. If your remote has a learning function and you have an original remote to hand, some have the ability to learn the function by direct lt beaming the remote command into the harmony itself.
Jun 15, 2010 | Logitech Harmony 880 LCD Remote Control
How do i adjust the treb/bass?
my initial reply was...On the function button you may need to depress it for 3 seconds to activate base, treble, balance etc But
then I found this, "Rotary Volume Control: The CD receiver uses a 7-way rotary volume control that increases and decreases the volume of the stereo from 0 to 35. The rotary knob also controls other audio settings such as Balance, Fader, Bass, Mid, Treble and preset EQ settings. In addition, the rotary knob allows you to scroll through and select your music tracks when the Music Search function is activated.
Cheers, this should help ya.
Jan 01, 2010 | Kenwood KDC-BT742U
The volume control on my KENWOOD TH-78A no longer functions
first of all check the volume control see if a wire broke off. but i suspect a cold solder joint on that volume control switch. if not check the board for a small crack.
Apr 10, 2009 | Kenwood PB-18,...
IMac keyboard volume control keys
Do the volume keys still work when you are booted in to OS X?
Also, try reinstalling the Bootcamp drivers that will appear when you insert an OS X disk when it's booted in to Windows.
Mar 16, 2009 | Apple iMac G4 20" Mac Desktop
880 universal remote volume button broke. little rubber botton on inside that pushes the volume button on inside broken.face plate cracked and arrow button on left right underneath face broken and missing...
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Mar 02, 2009 | Logitech Harmony 880 Universal Remote...
Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Jan 06, 2009 | Yamaha RX-V800 Receiver
I just bought a laptop do they have speakers built in? and if so where is the volume control I have a acer travelmate 200dx thanks Anne
volume control is normally located on the bottom right hand corner beside the clock, just double click on the speaker icon and you should be able to adjust the volume.
Mar 12, 2008 | Computers & Internet
Rio Carbon MP3 Player Logo
176 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
