Need maintenace schedule
Spark plugs at 100,000 (use AC Delco plugs, they work best), check air filter at 15,000 replace at 30,000, replace fuel filter at 30,000, service (fluid and new filter) automatic trans at 60,000, replace hoses and flush cooling system at 100,000 miles, (use long life coolant), check belt at 30,000, replace if any rubber in ribs is missing, cracks are ok per factory bulletin's. oil and filter at least every 5,000 miles, lube chassis every other oil change, more often if u drive short trips, lube the door hinges and hood hinges and all latches every 30,000 miles. If I missed anything you want to know let me know. one last note manual trans and differential change lube only if torn down for repair, otherwise it is lifetime.
