Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony TV stuck in stand by mode
Dan, the light blinks 9 times. Does that help any? I also have a sony triniton, same problem, my set
just sits on standby/timer mode, it is blinking 7 times, no souns and no picture. I did a hard reset and it still didn't work. Can you help me??
  • morgan1970 Sep 19, 2008
    My tv also blinks 7 times and will not come on. We have had no storms or power issues. Have also tried a hard reset with no result. anybody know what this means?
  • stackmin Apr 15, 2009
    How much to fix this common problem?
  • 59 Answers
The 9 blink code is caused by a bad diode on the pc board. The zero crossing detect circuit is not allowing the power supply to come on .
Posted on Oct 02, 2008
  • Shelby Cheek
    Shelby Cheek Feb 04, 2015
    Hos much does it cost to fix? Thanks,
How much is it to fix with either problem?
Posted on Apr 15, 2009
    Or am I just better of buying a new LCD/HDMI new TV?
    btw...I'm experiencing the 9 blink stanby problem.
  • Sony Master
  • 5,568 Answers
In both cases, I think you are either suffering from a failed power supply or the supply is cycling because of a 'downstream' problem that could be in the high voltage circuit. In each case, the blink count probably would tell you approximately where the problem is located but only a Sony tech will have access to the codes. After all, we are only mortals.
Posted on Sep 22, 2008
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Stand By timer light continues to blink on Sony Triniton TV
That problem comes up when one or both of the convergence IC's are burnt ... it normally has an "STK" number on it screwed onto some large aluminium heatsink ..... however if you venture to change it get back to me ... I'll try to guide you through ....
May 23, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron XBR, Stand By Mode?
Generically, the 6 or 7 blinks usually indicate a problem with the horizontal circuit. In order to provide accurate diagnosis and suggested solutions, the exact model number is needed. Please update this with tha number and I will post more details.
Thanks,
Dan
Mar 18, 2009 | Televison & Video
Sony triniton,no sound or picture,flashing red light blinking!
the main problem of your tv set is the main power or what u call the regulator.the red light blinking it means your tv set is on standby mode.
Feb 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
The 6 or 7 blinks usually indicate a problem in the horizontal circuit. Since the TV recovered once, the problem is most likely to be a bad solder connection in that area. If you can solder, resolder any connections on the board that appear grainy or have rings. That may resolve the problem. If not, update this and we'll look elsewhere for defective parts.
Dan
Sep 16, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Yes. The 9 blinks indiate a problem in the power supply area. I need to look up your specific model later today to get you the specific parts. If you are comfortable with soldering and working inside the set, you should be able to repair this yourself.
Stay tuned...
Dan
Jun 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 32" Triniton TV. Will not turn on.
The four blinks indicate a vertical deflection problem. I would suspect either bad connections on the vertical IC or a defective IC. This IC is a small flat IC with about 9 pins or so and should be marked LA7837 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC.
You may also need to replace some capacitors in the circuit, but try the IC first and keep us updated.
Dan
Mar 17, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
471 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
