FixYa.com
Tags:
Jensen VM9510 Car DVD Player
JENSEN vm9510 NO VOLUME (by 2 users)
posted by doug on Dec 16, 2005
Yes it seems that all functions seem normal but i have no volume how can i get it repaired and what could it be
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by slkirkconst, posted on Jun 27, 2008
the player has sub output but there is no other speakers playing everything seems to work fine just no sound.
Best Solution
posted on Feb 15, 2006
Thanks for Trying (70)
hendrix
Rank:Wiz Wiz
Rating: 77%, 659 votes
I am going to assume you are making a standard DVD-Video disk, since the other format takes more specialized and much less common software.
One likely possibility is that you have authored your disks with mpeg audio rather than Digital Dolby (AC3) or linear PCM (LPCM) audio format. MPEG format audio is commonly used in home DVD authoring but is seldom if ever found on commercial disks.
my guess is that your car player isnt set to properly decode mpeg audio disks. I would suggest you go through the menus / owner instructions for your car player and find the menu setting which allows your car player to play back mpeg (rather than Digital Dolby or LPCM) audio, and your disks should then play fine in the car.
Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 19, 2008
Not Rated (0)
nitla
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi.
I think that your problem is the sound IC which is located in the back of your stereo and it's mounted with heater sink.It is hard for you to replace it unless you are a technician.Find any friend of yours who can do it because going to a service shop will cost you.
Can you Help with these Car Video Players problems?
jensen vm9510
hi, please help, how can i... Answer This...
NEED Harness For XDVD 700
NEED back Harness For XDVD 700.... Answer This...
Jensen volume
everytime i turm my car on the... Answer This...
Jensen VM9510
No sound in am or fm, not even... Answer This...
The loud feature on the VM9512
Trying to turn on the loud... Answer This...
Repair Service
Find Car Video Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
