Question about Epson Stylus Photo R1800 InkJet Printer
Epson fixing ink pad problem
When tried to connect to the servicemanualshop.com as you suggested all i keep getting is advertisement for flower web site
  • Epson Master
  • 691 Answers
The site has been bought by someone else and appears to have gone. What did you need? If it was a rescue kit for an R300 try this link:
http://www.tradebit.com/filedetail.php/816199-Documents-eBooks-Technical
If was another product, let me know which and I'll try to find you a source.
Posted on Sep 06, 2008
Epson t60 printer ink pads are end of their service
This is not a question.
I suggest you google 'what is a question'
read up on it and then return with a plausible one.
Nov 25, 2014 | Epson Office Equipment & Supplies
Why my epson stylus c 67 ink and paper flashing alternately and cannot print, printer occured a problem
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly.
http://www.ssclg.com/epsone.shtml
http://www.dailymotion.com/video/xgkbji_resetting-protection-counter-on-epson-printer-ssc-service_tech
Jan 09, 2013 | Epson Stylus C67 Photo Printer
Replacing waste ink pads on epson rx685
Actually it will very hard for you to access the ink pads for it was designed to be only touched by their service center. I would pressume your printer is giving you errors on waste ink pads full? Try this to reset the counter and be able to use your printer again..
http://fix-your-printer.blogspot.com/2010/04/how-to-reset-epson-stylus-photo-rx690.html
Sep 25, 2012 | Epson Stylus Multifunction Inkjet Printer/...
HI! This is the printer's problem: The printer's ink pads are at the end of their service life. Please contact Epson support. Model is Epson Stylus T13
http://www.2manuals.com/reset_wip.php
so officially the ink pads are full and need to be changed. However try to find them available to get to change them and you will find that it will be impossible. Crazy for such a simple fix but they just don't sell them. so the above link will tell you about possibilities, and you can get the waste in k reset on epson's web site by putting in the serial number of your unit. The first thing you need to do it clear the printers problem and that can be solved easily. the second is that you can put in new pads if you can find them. here is how on a different model.
http://www.youtube.com/watch?v=6iJqLDfAOys&feature=related
Aug 31, 2011 | Epson Printer
How can I make a permanent fix to the waste ink reset? The problem started with three solid red lights on display panel from L to R when giving the printer a job to print out. I have tried one fix...
Have you tried cleaning them?
Found this on web helpful. If you find this helpful, pls rate me.,,,,,,,,
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues.
Thanks and Good Luck :0)
Jan 29, 2010 | Epson Stylus 880 InkJet Color Printer
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
R265 FIX
TO ALL USERS of epson R265 on this forum
THERE IS A SERVICE PROGRAM TO RESET THE PAD INK COUNTERS FOR YOUR EPSON R265 ON THE WEB!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
web adress: www.eserviceinfo.com
and there You look for service program or ajustment program/software for epson R 265/R270
Mar 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Service life has ended on my epson stylus r320 photo printer
Thanks for your selflessness Steve H. describing the RESET procedure for the Epson R300 by simutaneouly depressing the POWER, STOP and MAINTENANCE switches.
I checked with Epson, via telephone, and they recommended going to an authorized dealer for ink pad replacement (approximately $100) or buy a new printer ( $150 - $250).
After completing your suggested RESET procedure successfully - I went a step further and mopped up the excess ink that was evident on the 'black ink pad' which was saturated with black ink. I used Kleenex which seemed to mop up the excess BLACK ink nicely, and continued this mopping procedure until there was no evidence of black ink on the Kleenex. There was very little evidence of spilled ink on the color pads.
Time alone will tell. So thanks again Steve - you saved me $100 to $200.
Oh yeah! I LOVE this printer.
Dec 13, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
