Question about Canon imageCLASS MF4690 Multifunction Laser Printer, Copier, Scanner & Fax, 21ppm, Maximum Size: 8.5
New cartridge but copier not printing
What may be the problem when a new cartridge is installed in canon imageclass copier and no images appear.
  • 1,219 Answers
Did you pull out the orange/red tape?
Check if there is an good connection between cartridge and pin at the right side of crg. inside crg.holder( a little pin wich goes in and out when you open or close cover )
Try with old crg. if it works the problem is new crg.
Posted on Jan 13, 2010
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
Canon D760 print problem - print image
Duplicated images on pages is either the drum, or fusing/setting unit. Since this is an all in one unit, I am assuming the ink/toner cartridge includes the drum. I suggest replacing the fusing/fixing unit. (the hot part of the printer"
Aug 15, 2012 | Canon imageCLASS D760 All-In-One Laser...
Canon d320 image class makes knocking sound and nothing prints
First be sure that your printer cartridge is Ok (not blocked). Did the Canon feed the paper? Can you print, or there is a problem with scanner section
pifonski
Feb 20, 2011 | Canon imageCLASS D320 Digital Copier
I bought a new Canon image clas MF3240. I installed the software but it does not print. How do I print?
Make sure the software is installed correctly. Add your new printer on your hardware in computer to make them paired perfectly.
Jan 05, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
Canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
Oct 05, 2009 | Canon SmartBase MPC400 All-In-One InkJet...
Canon image D320 copier doesn't copy entire page
Dear sir,
its problem copier fuser unite
fuser cover is broken .Change it near by copier expert and then solve your problem
Aug 14, 2009 | Canon imageCLASS D320 Digital Copier
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Mar 26, 2009 | Canon imageCLASS D320 Digital Copier
Canon imageCLASS MF4690 Multifunction Laser Printer, Copier, Scanner & Fax, 21ppm, Maximum Size: 8.5 Logo
110 people viewed this question
old marine
old marine
