The freezer on my Liebherr fridge keeps filling too much with ice. The ice grows around the door and seal which makes it impossible to close properly. I inherited the f/freezer so I don't have the instructions for how to defrost. Anyone know?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This sounds like moisture in being sucked in past the door seals. Remember, cold-- sucks temperature, (like a vacuum) and HEAT--- pumps away temperatures..So the warmer temp. are always being drawn in.. Thus, bad door seals, and need to be replaced --- cleanned---or repaired, but for now turn your thermostat or temperature up or the control knob back lower, (like from 7--to 5--ect. ect 4-to 2..)!
Posted on Sep 06, 2008
Liebherr ice maker not making ice. Switched on but nothing happening
Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
Jan 04, 2017 | Liebherr Refrigerators
Door seal no longer efficient. Can you help
Get some scotch tape and inbetween uses wrap a load of the stuff round and round the fridge, That should keep the door closed. For ease of use keep a stanley knife nearby so you can get at your food etc
Mar 11, 2011 | Liebherr KIB 2544 Premium BioFresh Top...
Alarm is going off (beeping) - ice accumulating on rear freezer wall.
hi check the doors seals if it closed perfectly and do not open the fridge or freezer door for long time because if you forgot one of the doors open it will make this problem and do not put hot or warm food inside most important to be sure that the seals stuck good when you close the fridge doors.
Sep 11, 2010 | Liebherr Refrigerators
We have the Kenmore model #795.78309.800 and the freezer drawer track keeps freezing up and make it almost impossible to open the freezer. This just started the other day.
the most common problem is a bad sealing door ,when the door is closed it is not supposed to let warm air in and cold air out ,but if the seal is faulty then the opposite happens and this causes the build up of ice,take a good look at the door seal a good way of finding out if this is the problem is to run your fingers around the seal when the door is closed for a while if faulty you will find a warm spot where the cold and warm mix causing a warm spot.adrian,,,,,,,,,,
Aug 13, 2010 | Kenmore 22.4 cu. ft. Bottom Freezer...
The fridge and the bottom freezer are working fine. However there is a lot of ice developing at the bottom of the (bottom) freezer. Although we recently de-frosted the freezer and removed the ice (water),...
there is only 2 things if you dont have an ice maker inside your door is not sealing all the way around or the drain is cloged with ice and everytime the ref goes into defrost the water leak into the fzr unplug for 2 days that shoud fix it
May 30, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
Our N369B fridge freezer has a large amount of ice clinging to the upper back of the fridge how do we stop this happening?
Your freezer door is not closing properly. if it is not on wheels then make sure the bottom nut that also holds the front wheels or slider in place is tight. Also maybe have the seals replaced and check door alignment on both doors. You will of course have to defrost the freezer.
Oct 27, 2009 | Fisher and Paykel Active Smart E522B...
Ice keeps accumulating in back of fridge. We've tried cleaning drain but it doesn't seem to help.
If the drain is clean and there is sufficient space for air to flow around the food, the only thing left is to replace the door seal. It is allowing moisture to enter the freezer. The fan inside the freezer, actually burns the frost off of the food. If the seals are bad, it can never catch up.
Sep 17, 2009 | Liebherr Refrigerators
The freezer compartment on my fridge keeps icing up over a couple of months. How can i prevent this please.
if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes:
1. low refrigerant
2. no fan
3. too much humid air in fridge/freezer due to door open or bad door seals
4. the condensate drain tube is clogged
if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s).
no air, no fan. Replace
if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional.
defrost solutions:
unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Sep 01, 2009 | Refrigerators
Maytag Refrigerator Model MSD2454GR
I had this problem and it was due to a poor door seal. Check around the area where the ice is forming to see if there is air leaking from the freezer.
Sep 08, 2008 | Refrigerators
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
