Question about Clarion VRX935VD Car DVD Player
There r a load of wires to the one i just bought
If u conect the sterio to a batery and insert a dvd should u get a picture straight away even if its not in the car
    Brigadier General:
  • 6,966 Answers
Sorry for a very late reply. Your concern was just recently brought to my attention.
Basically, for a Clarion VRX935VD to work outside of a vehicle, there are 4 wires that must be connected other than the speaker/amp connections. These are:
  • Red - to the +12 supply (normally an ACC/IGN B+12 in the car);
  • Yellow - to the +12 supply (normally an always on B+12 in the car);
  • Black - to the GND or - of powersupply or battery; and
  • Grass Green - switching negative (normally to the parking brake switch in the car).
Additional information on the wiring and installation may be found here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 13, 2008
93 yamaha PWC. Starter will not diengage even when ski is running. when key is pulled and engine is cut the starter is still spinning.\ \ sorry, no category for PWC, listed under motorcycles
THIS SOUNDS LIKE THE STARTER SYLINOID IS STICKING ,,,YOU WILL NEED TO REPLACE IT YOU CAN FIND IT NEXT TO THE BATERY,,,THERE IS A BLACK BOX WITH A LOT OF WIRES COMING OUT OF IT ,,TAKE ALL THE SCREWS OUT OF THE BOX AND YOU WILL SEE WHERE THE BATERY WIRE AND THE GROUND WIRE IS CONECTED TO THE SYLINOID DISCONECT THE BATERY AND REMOVE WIRES FRON SYLINOID AND REPLACE,,,HOPE THIS HELPS.
Jul 12, 2011 | Yamaha XJ 700 X Maxim Motorcycles
I load the disc in my player, and I get audio, but I get no picture. What am I doing wrong?
Hello sir in which player are u trying to play it ??? Whats the video format ???
Mar 13, 2008 | Televison & Video
Tip
No audio even though sterio wires are all connected
My 1997 Alpine CDE-7828's wiring schematic doesn't disclose one important thing for many older and possibly even some newer sterios (aka 'head units'). If all wires are connected per the sterio's schematic andf sound is missing, you probably have a dedicated pin on yout vehicle's harness/connector that will read something like 'Turn-on AMP signal", <br />until you jumper the ignition hot lead (between the harness plug and your sterio) to your vehicle's 'Turn-on AMP signal' pin/connector wire (add a wire if none is supplied in your vehicle's connector), you won't get any sound even though all the other wires are connected per your head unit''s instructions.
on Nov 06, 2010 | Car Audio & Video
It wont crank like not getting power
ok sounds like you have a dead battery
1) if turns but slowly:
posible causes:
1.1) old dead batery/
or underchaged battery >check altenator in this case
did you leave your headlights turnt on and drained the battery of its charge?if so get a jump start and then run the car for 30-45 mins to rechagre the battery
if you have at your disposal anothere batery that you know has a good charge
try starting your car with that batery(not using jumper cables) hook it up!
if the slugish turn over is still there
1.2) check your wire conections for corision this means completly disconecting 1 lead at a time (only on one end of that lead)and cleaning them with a wire brush or some sand paper.
(on the battery and the starter also the ground strap conection to the frame.)
2) WONT TURN OVER AT ALL:
posible causes:
2.0) dead battery >try charging it>get a jump start
2.1) blown turnkey igntion fuse
2.2) blow fuse for main har nes wires
2.3) bad starter
2.4) corosion on wire conection (most often the batery terminals)
2.5) starter replaced and hooked up incorectly.
2.6) alram system preventing the turnkey igntion system from getting power
Feb 24, 2010 | 1994 Mazda 626
Radio and clock not working
ceck the fuse in the fuse box and the fuse on the back of the stereo, conect the sterio direct to the batery if is warking you may have a sort cirkuit.
Dec 17, 2009 | 1997 Ford Escort
Wont coection for car sterio where can i get the wire conction
i am wonting the conection which plugs into the sterio it is a moca050 mooo3221541 it as two sets of 8 pins it is this plug that i require thank you
Nov 06, 2009 | Car Audio & Video
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
No wires with PIONEER AVH-P6400CD
This particular model it doesn't need an external brain to work.
You can get the wires (pwr harness and rca plug) from pacparts.com
Jan 20, 2008 | Pioneer AVH-P6400CD Car DVD Player
Why do some DVDs play well and others don't?
just check the data transfer wires.may ur probles sloved
Mar 06, 2007 | Power Acoustik PADVD-150 Car DVD Player
Clarion VRX935VD Car DVD Player Logo
150 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
